EK fog lights
EK fog lights
Fog and Corner Lights; the red light is my red interior dome light
Headlights and Foglights
A buddy of mine says that my lights look like a alien haha
The following 2 users liked this post by 03tLsNBP:
bl3ujay07 (11-16-2011),
KatabaticSaint (11-16-2011)
I'm a thrill seeker in my
I'm sure the lights look pretty good but the pictures are AWFUL. The thing is, when you have openings for fog lights already putting lights in the lower part of the grill just doesn't seem right.
3 pedals in my 99 TL
Word. I would have cut it and fit it in the lower grill part. Doesn't flow right how it is imo. might have been more work but i think the look would have been worth the extra work.
honestly its look okay, but the main thing thats killing your flow besides that tow hook, is the spaces that the JDM fogs were supposed to be in, its a reason why that area is dark, so fogs can sit in that location. To me your car would look way better with the JDM fogs which can be found, if u try looking. And with the EK fogs, u slim down the front way more, with the way u have the fogs sitting closely together. While if you look at the original location where the fogs were supposed to be at, it would make your car look more wider which would look way better.
the dummy fog light hole on my driver side is space taken up and being used already for a different Functionality. i like where my lights are due to Function>Form.. im not going for the wider "look" either... why would i want to "look" like everyone else who has the "proper" fog light in the "proper" location?... a car wouldnt be individualistic if it was done the "proper" way... btw.. tow hooks work! ugly as sh*t from the front.. sure... but they are functional... i dont have parts for looks... i have parts that Work.
MechEng
^ to each his own.
I still have to install my tow hook, but I am going to mount it wayyyy further back so it doesnt stick out past the front of the bumper. I've run into more than a few occasions where it would have helped when I'm at my school's off road test track.
BTW.... the tow hooks work great when needed to tow a DA Integra 30 miles on the freeway;... not saying that i did it buy hypothetically.. it works
TL test track?.... what school is this?
The following 2 users liked this post by n1njai:
Flipster23 (11-17-2011)
Regional Coordinator (SoCal)
You wanna talk about functionality but the "proper" mount spots for the fog lights are on the ends, you see way more, the light beams are wider meaning you see more of the road. The way your fogs are mounted atm give you a narrower view of the road which is already what the lowbeams are doing for you. The towhook where u put it, idk but i've seen at the tracks wayyyy too many cars with that tow hook that just got yanked straight off. Your stock ones are sufficient enough which is directly under the engine. I like your idea of being individualistic, but there's a way to do it cleanly. The way you're doing it now, seems like it's all over the place to me, an eye sore considering where you decided to put some of your mods.
-Arsenic-
the way that my fogs are Actually mounted gives me a wider view then mounting the fogs on the sides like you think.. my fog lights Don't aim directly in front to give the narrow lighting... angling the fog lights beam outward gives me a MUCH wider OR wide enough visual of the road. ill post better pictures later...
picture is of fog lights and low beams on.. notice the faded beams of light off the left bottom side and lighting up the section of the bush.. stock low beams don't beam to light up that area of visual.. area being the bush, so for me, they've been working pretty darn sufficient, like my tow hooks that allow me to hook with ease instead of bending over on hands and knees to reach the stock hooks, and since ive been hooking up without any yanking off of the tow hook yet.. i guess that my tow hooks are pretty darn sufficient as well
fuctionality is not ment to be pretty, thats where function>form (function OVER form) plays a roll.. the way something Works OVER the way something Looks
Rev High; Drive Happy
Not bad.. but wouldn't you get an even wider beam if you did the same thing where the fogs are normally supposed to go?
And if you mounted it normally, it would give a pretty sufficient wide beam. Angle it just a tiny bit and it'll get wider just as you did when you put the in the center.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
