XS Header Question
Old Jun 15, 2008 | 05:17 PM
MyPearl02's Avatar
XS Header Question
This would be much help to me if someone could tell me and easy way to get my O2 sensor out and does it make a differnce which manifold goes on what side
thank
PS this is a pain in the ass alone!!!!!!!!! but the install is not all that bad
Old Jun 15, 2008 | 05:27 PM
oVerBoost's Avatar
HELP!
i just used a regular wrench to get the O2 sensor out. and the manifold with the little notch on it goes in the back. here's a tip...bolt to back manifold to the downpipe first, then the front second. for some reason when i did the front first, i couldn't get the back manifold to allign correctly. well, atleast that's what i ran into.
Old Jun 15, 2008 | 11:54 PM
6MTUA5's Avatar
No He Can't
Use an adjustable wrench for the O2 sensor and like he said, notch goes in the rear.
Did you get new bolts for the kit?
Make sure you tighten everything little by little so everything is lined up good.
Old Jun 16, 2008 | 03:53 AM
ABClaypool's Avatar
Where do you guys get the bolt kits for the new headers? Could you just get them at pretty much any auto shop?
Old Jun 16, 2008 | 05:40 AM
joseph_99tl's Avatar
i am replacing my j-pipe and i am looking for stainless steel
nuts and bolts...in this m10x30 size.....they're hard to find
Old Jun 16, 2008 | 07:37 AM
fsttyms1's Avatar
Any hardware store. try to find grade 8
Old Jun 16, 2008 | 02:35 PM
6MTUA5's Avatar
No He Can't
Home Depot, Lowes, Ace in the hardware section
Old Jun 16, 2008 | 02:52 PM
ABClaypool's Avatar
ok thanks, i wasn't sure if i needed to buy some particular kit or something
Old Jun 16, 2008 | 08:49 PM
MyPearl02's Avatar
ya that was the first thing i went and did everything is on now i got her done last night i had about 5 hrs into it doing it alone it runs great huge noticeable difference in performance and sound my intake will be here tomorrow ill throught that on and then take her for a drive
Old Jun 19, 2008 | 09:52 AM
ParadoxJr's Avatar
I just had my Headers, Magnaflow Cat-Back and AEM CAI V2 put on, on friday. I AM LOVING IT!!!!!!!
I just need to get it tuned now. I cleared the ECU, but want to invest in the Jet ECU Tune.
Has anyone tried it?
2000 Acura TL
Old Jun 19, 2008 | 09:54 AM
i dont think these cars need a tune with what you have installed.
Old Jun 19, 2008 | 10:14 AM
ParadoxJr's Avatar
I know they don't need it, but from what I have read we should be able to pick up about 5 to 15hp and up to 3 or 5mpg.
I HOPE!!!!
Old Jun 20, 2008 | 05:17 PM
kunfuzed's Avatar
i just got my xs-p header in today
was wondering if anyone has wrapped there header with exhaust wrap?
Old Jun 20, 2008 | 05:21 PM
6MTUA5's Avatar
No He Can't
I don't recall anyone wrapping the headers, but a few of us have wrapped the flex pipe to get rid of resonance.
Old Jun 20, 2008 | 11:34 PM
corpsdawg's Avatar
From what i've heard most after-market companies do not recommend wrapping the headers because they'll get heat soaked and the welds will lose strength and come undone... or something like that. Wrapping the flex pipe is alright though.
Old Jun 21, 2008 | 01:08 PM
6MTUA5's Avatar
No He Can't
That makes sense and the welds on the XS headers are shitty enough as they are.
Old Jun 23, 2008 | 09:36 AM
ParadoxJr's Avatar
I will be wraping the Flex Joints soon. Leaving the headers alone.
Old Jun 23, 2008 | 04:19 PM
02type-s's Avatar
-Arsenic-
Does this really work? I wanna pick these up but I wouldn't be able to deal with the resonance.
Old Jun 23, 2008 | 04:59 PM
6MTUA5's Avatar
No He Can't
I've heard that it has worked for some members, but didn't work for me. I even went as far as getting a new flex pipe welded into place to get rid of it but to no avail.
I think it has mostly to do with the install. It was my first time doing headers and I did it by myself and I think the O-ring gaskets for the manifold to J-pipe didn't set right so there isn't a good seal. You might as well go ahead and try them out for $100.
Old Jun 23, 2008 | 08:36 PM
MyPearl02's Avatar
i have no resonance at all in mine i just got my intake on theres a huge noticeable difference in power and sound but im skeeming away on a custom turbo kit i just have to do alot of measuring and calculating to make sure it will work before i go and drop the money on something that doesnt work
Old Jun 24, 2008 | 07:47 PM
02type-s's Avatar
-Arsenic-
Is it going to be considerably louder? I already have the WS2s.
Old Jun 24, 2008 | 08:37 PM
6MTUA5's Avatar
No He Can't
No the headers won't make your exhaust that much louder, just a nice scream at higher RPMs.
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
DerrickW
Nov 15, 2015 05:52 PM
