Whats the difference between tl-p and tl-s
Originally Posted by david-s
better yet what is a tl-p anyways, never heard of it. whats the difference between the it and a tl-s
TL-P: 225 hp, 16" rims
TL-S: 260 hp, 17" rims, firmer dampers and springs, thicker anti-roll bar, improved intake. Interior: Triangular shape headrest, TypeS shift knob.
Originally Posted by tst32tl
In short version
The engine has higher compression, more agressive cams, duel stage intake manifold, improved flow intake, improved flow cat, exhaust/mufflers. Firmer suspension, thicker sway bar(s) silver guages, perforated seats, 17inch rims. VSA 4 channel ABS.
oh that model?! so tl-p is just the base model tl. so then why do all call it tl-p just a waist of energy. lol
Originally Posted by TOTAL~LUSH
how does the dual stage intake manifold work anyone know?
"At lower speeds, the two cylinder banks are separated by a closed valve. This allows intake resonance- essentially energy waves echoing within the plenum chamber- to pack more air/fuel charge into each cylinder. As engine speeds increase, the valve opens and cancels the resonance. The inertia of the intake charge then creates a superchargine effect for greater peak horsepower".
The Type S also gets a forged steel crankshaft. Advanced spin-cast cylinder- liner manufacturing technique that helps reduce weight and improve engine cooling.
MetalGearTypeS
Aug 29, 2016 08:28 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
