Day light running lights
Old Aug 15, 2008 | 06:58 PM
deep's Avatar
9th Gear
Thumbs down Day light running lights
Hi. I bought a 2003 TL a year ago from the US and imported it to Canada. I got the dealer to install DRL. They charged about $200. The dealer says that they had to make my regular lights the DRL lights also. They said they can't do it to the highbeams. Is this true?
The problem is that my driver side headlight inverter went out and probably because the normal headlight has to work for both day and night. Double shift.
Any thoughts?
Old Aug 20, 2008 | 11:11 AM
CJITTY's Avatar
Ackniculous One
Should be high beams only...HID's are not meant to be on at lower wattage and constant on/offs...what kind of dealer you got there? A better option would be to use the fog lights as your DRLs if they let you
Old Aug 20, 2008 | 01:20 PM
Edward'TLS's Avatar
6G TLX-S
Deep, yes it's true. For the 2nd gen TL, the Canadian spec. TL (with daytime running lights [DRL]) has a completely different headlight circuitry than the US spec. TL (without DRL). In order to retrofit OEM DRL into an US spec. TL, you virtually have to rip out and rebuild the complete headlight circuitry. It's not like those aftermarket DRL units that only need to splice in a couple of wires.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
space_boy
ILX
51
Aug 15, 2017 12:06 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
