what do the lines going into the intake/air box do?
hey, i was wondering if i need all of the lines that go into the intake pipe and the lines that go into the stock air box. if i make a custom intake pipe will i have to put all of these lines into my intake pipe?
thanks
thanks
you can get carb ice/ throttle plate ice anywhere in the country at any time of year~
Its not a good idea to bypass/route the 2 coolant lines- they provide a needed heat source where the air temp/humidty levels suddenly change by venturi action-
IF you were a car racer then do it for track cars
they go to the TB anyway
On your custom intake pipe- the metal pipe from the valve cover needs to go into your new pipe- its the crankcase vent and the engine will explode without it, and the various hoses all have a purpose/function.
Check out different brands and homemade unit pics- snow or deep water can be an issue
The cheap semi-cai is to remove the lower intake resonator box- same as you would to install any CAI, and that opens the 2 large holes in the bottem of the airbox.
Instant more air volume available to the engine-without restriction or worry of puddles
The lower splash guard has drains and the upper area where the air filter box is- you would have to be in water way up the doors to get it wet
At which point- as you float down the river on the tv news--the engine getting water in it is the least of your concerns!
ok, so i checked out some aftermarket intakes and they look like they have the 2 or 3 lines going into them, i guess i will just have to weld on some nipples onto my pipe for them to go on, does anyone have a close-up of the spots where the lines go to on an aftermarket intake?
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
