True dual exhaust?
True dual exhaust?
Hi, im looking to do a custom exhaust and was wondering if anyone has done a true dual. i have a buddy that will weld everything i just need some help on what to do about the catalytic converter since its illegal to drive without one, what size piping to use, what to do about the resonator, and mufflers... Im new to modding so any little bit will help.
Thanks in advance.
Thanks in advance.
one problem with that exhaust is there are no cats? i thought we need cats to be legal and with my luck i will get pulled over and have that checked. where could i put a cat, or cats? and have the same flow...
You'd probably have to go aftermarket or custom for the cat, since I'm guessing the TL's cat has one pipe in and one out. I think it'd be easier to custom fit two smaller cats, like jjashaa said.
TBH I don't see the benefit of fatty's setup there, one pipe in the cat and two out? Wouldn't a single exhaust be more efficient?
1 cat is legal
There is a large cat and a small cat.
The small one can go.
The small one on mine is gone.
#3 in diagram below..
if anything... run 2 or even something like this..
that could act as an X pipe as well assuming it crosses over inside. and get o2 bungs welded in and run defoulers.
if you're so worried about smog.
don't touch anything.
So would it be better if i just went with a set of headers and do a mid muffler and res delete? i am just looking for more flow and a little nicer sound. i was considering a dual for the flow but i think that will be way too much work.
thank you again for all your help.
if you're looking for a nicer sound... leave your mid muffler and resonator in (iirc... tl-p doesn't have a resonator only a mid muffler..)
headers are a good start... you could also get a xlr8 high flow cat.. its easy to install and take off..
wtf are you talking about... 2G has only 1 catalytic converter...
I Was/Am considering this to replace my setup and run true dual when i put the new motor in. Im not a fan of the exhaust smell without one.
Look for him here
https://acurazine.com/forums/sponsored-sales-group-buys-10/
i'd suggest doing headers and high flow cat.
if you want to do an exhaust.. you could go custom..
2.5 ID piping to 2.25 Y split and two mufflers of your choice.. magnaflow seem to be popular.
InFaMouSLink
Oct 30, 2015 09:43 AM
joflewbyu2
Oct 8, 2015 11:16 AM
SiClone
Oct 1, 2015 10:22 PM
AcuraKidd
Sep 25, 2015 11:18 PM
