Test Pipe or Hi Flow Cat
Hey i was wondering if they made a test pipe or a hi flow cat for 02-03 TLS' thats direct bolt on like this
http://www.meganracing.com/products...did=95&catid=24 thnx |
I have teh high flow cat made by Random Technology, it's straight bolt on for a TLP, av6, or CLP...but requires a bit of modification for the type S, i believe you have to extend part of it to get it to fit. You also must buy a o2 extension wire, your stock wire won't be long enough.
did u notice a difference with the increased air flow?
2ndgentl
Get a test pipe made if you can.
Random Technology makes a bolt on unit. The only modification required is to extend the 02 sensors about 4". I sell 02 extensions to make it plug and play. On the Type S you will have to drill out the exhaust flange holes on the B-Pipe (cat side) to bolt up the cat. That is it.
https://acurazine.com/forums/sponsored-sales-group-buys-10/random-technology-high-flow-cat-sale-tsx-cl-tl-350743/ |
i appreciate it i will definitely be in touch
It felt a but more peppy, but it's prolly just in my head. |
how much louder did exhaust get? and how does exhaust tone sound?
exhaust seemed a bit higher and louder, but it's not a bad sound. |
Test pipe will make your CE light come on. Trust me. My 99 had 169,000 on its stock converter and the light was on. Code showed Catalyst below threshold. I took the stock converter off and knocked all the crap out of it and put it back on. I thought, what the heck, the worst that can happen is I have to buy a new one. I reset the light and all was good for about 150 miles, then the light came back on. Bought a new converter from Eastern and all is good now.
I have a high flow of magnaflow
omni power test pipe. 2.5 inches
