Which T/B Spacer To Use?
yes i did look at the vendors but thanks MilwaukeeDave im def going to go with the set...also how long did the install take you and how did you like the before and after performance wise?
I didn't really notice much difference in performance - but at $4.30/gallon, I really never punch the throttle anymore. I think based on the graphs on their website, you lose a very little in low end performance and you get significant boost in the 2500-4500 RPM range? Dunno. I bought it cause I figured I was cleaning my EGR port - didn't really care for any performance upgrades.
Former Sponsor
The Outlaw setup is just a thick gasket. P2R makes TB spacers and thermal gaskets.
http://store.excelerateperformance.c.../i-237039.aspx
That link to the P2R kit only has the throttle body spacer, but there is a link on the same page to a kit with the intake manifold spacer as well. The Outlaw Engineering kit has both spacers plus the coolant by-pass fitting.
For coolant bypass just remove the in/out line and put them back into the system no need for a kit, maybe some caps for throttle body but you can use the lines on the car for that too
As for p2r only for type s...not true go to there Web site they make them for non s i got one on the bm for 75 with 2 gaskets, and got the other spacer from heel toe 35 shipped
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
rockvilleTL
Sep 19, 2015 04:44 PM
