Straight piping 2000 TL
UA7_Unknown
So I know this is a fairly beaten topic, however i could not find a definitive answer in my search on the forums. I currently have a 2000 Acura TL as a project car and have deleted the mid muffler and resonator; leaving the CAT and stock rear mufflers installed. I would like to delete the rear mufflers and potentially reinstall a resonator. Based on the opinions of a couple colleagues of mine, they state that doing so without installing a resonator could cause bad back pressure; potentially burning exhaust valves. From my research on the forums, I do not see anyone having any issues with this and have also seen a couple users state that back pressure for the J-Series engine in particular isn't necessarily relevant to a straight pipe exhaust setup. So of course I wanted further insight from other 2G TL owners on this; (and yes I know straight pipes are considered "rice" but as this is a project car and a modification I would like to make, I could do without the rice commentary).
ProfessorFunk (11-21-2019)
01 tl
Hey i have an 01 tl with the cat deleted along with mid muffler. I removed the stock manifolds and downpipe also and put headers and apexi 4" mufflers on. Duals. It's loud but its not ricey until about 3000rpm. In addition I have a cold air intake which sits just behind front tire where the resonator used to b. I like the sound but could do a little throatier sound. Hope this helps
UA7_Unknown
I went ahead and said screw it and straight piped it. Doesn't sound terrible to me and I've had nothing but compliments from friends. I'll post a clip once I get the time.
UA7_Unknown
I know it’s been a while since I’ve posted on this thread, but wanted to get everything on the car before an update. Ended up putting the stock rear mufflers back on since I put Megan headers and a gutted cat on (which sounded horrible just straight piped). Am looking for some decent mufflers now to replace the stock ones. Will post a couple sound clips soon of what the car sounded like 1st with the rear mufflers, resonator and mid muffler deleted. Will then post a 2nd clip with its current setup, Megan headers, gutted cat, straight pipe to stock rear mufflers.
Latent car nut
Received 2,005 Likes
UA7_Unknown
Just curious.
How did you resolve the megan headers with downpipe misalignment issue you had upon installation?
Just curious.
UA7_Unknown
Oh yes, I forgot to mention that PITA. I had to drill 2 of the holes on each header out to a larger size so that the bolts would fit through properly. Once that was done everything lined up perfectly. Driving it for a couple days then will recheck to see if anything needs to be re-tightened.
If so, how are they working out? No leaks, I presume.
UA7_Unknown
I just got OEM ones. So far there doesn’t appear to be any leaks. I’m probably gonna get a high flow or just OE cat soon as I do not like the current sound of a hollowed cat. But as far as performance is concerned the car drives great.
zeta (11-21-2019)
TheWanderer316
10-28-2008 01:03 PM
jhood
08-13-2006 11:59 PM
