springs/shocks
Old Aug 15, 2012 | 06:17 PM
ibs's Avatar
ibs
springs/shocks
I already have 19s on the tl. I dont want to spend all the money it would cost to get coilovers so Im deciding to buy springs and shocks. I wanna lower the car 1.5 inch maybe a lil more if possible. I understand I need shocks as well. What is the best brand? Tien s tech i hear is nice. looking to spend no more than 300. pushing it is 400.
Old Aug 15, 2012 | 06:38 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Tein s techs are over 2" drop. I would go with h&r sport springs(1.75"f &1.5"r) with tokico blues.
Old Aug 15, 2012 | 07:30 PM
fsttyms1's Avatar
3-400 With shocks? Not going to happen if you want the best brand. Best brand of spring is H&R. Best brand of shock is Koni or Bilstien.
Old Aug 15, 2012 | 08:38 PM
ibs's Avatar
ibs
Never thought it would be that much might as well save an extra couple hundred.. but will the actual ride of the car be more stiff? I dont want to start rubbing. I just fixed that problem
Old Aug 15, 2012 | 08:57 PM
It is worth the extra couple hundred to get a better shock. I was going to get koni yellows but got to good of a deal to pass up on my kyb agxs and they are actually easier to adjust than any of the others in the rear. I would think you would have less of a chance of rubbing with a stiffer shock because it will have less room to travel because it is stiffer.
Old Aug 16, 2012 | 08:32 AM
Mr. Maker's Avatar
I have S Tech's and Tokico blues. Very nice drop and rides great.
Old Aug 17, 2012 | 07:41 AM
fsttyms1's Avatar
With adjustable shocks you can tailor the ride firmer or softer.
Also, why are you worried you would you start rubbing? Because you are lowered or some other reason?
Old Aug 17, 2012 | 03:39 PM
bonknhead's Avatar
Totally agree, for obvious reasons...
Yep - my H&R Sport Springs were $240 and my Tokicos were $315. Installation was another $150. So worth it though - the ride is better than stock - firm, controlled, but not harsh.
Old Aug 20, 2012 | 12:58 PM
ibs's Avatar
ibs
I'm not lowered but I have a probox with two 12s and their pretty heavy. And Im always the dd so I take friends around so my car is normally full just don't wanna be rubbing
Thanks everyone looks like the h&r and the blues
Old Aug 20, 2012 | 01:51 PM
If you get the h&r. Make sure you get the ones that have the part number 50103, NOT 51855. The 51855 were made for the accord and when put in the tl they sag to much. H&R revised them and came out with 50103
Old Aug 20, 2012 | 10:24 PM
ibs's Avatar
ibs
should i get the ones from ebay or are those not legit? I dont like ebay all that much. i know excelerate got them for sale.. just tryna save a couple bucks
Old Aug 20, 2012 | 10:40 PM
I got mine off eBay for like 200 shipped. As long as it comes in a H&R box and the part number is right I would go for it to save a little.
Old Aug 20, 2012 | 11:31 PM
Skirmich's Avatar
Ebay does sell Original Parts just look out for the RIGHT Seller! Everything from a Shaddy Seller in Hong Kong is a NO GO!
Me myself has H&R Springs with Tokico Iluminas could not be happier! Only Adjusting Rear Dampening its a PITA.....
Try KYB AGX like Stephen has, They have Externally Adjustable Dampening (In the Shock Itself not in Shaft like my Iluminas) so they are Easy to Tailor.
Old Aug 21, 2012 | 08:02 AM
I myself could not be happier either my car has little to no lean in corners now. I wanted the koni yellow shocks but found the kyb agx shocks for a price you could not beat. Adjusting them is really simple to just use a screw driver up front and lay on the ground behind the rear wheel and twist it or you could reach throuh the wheel but it's hard to see the numbers. I actually bought my springs and shocks off of eBay, I don't mind using them because your protected by paypal and your credit card company.
Old Aug 21, 2012 | 01:35 PM
fsttyms1's Avatar
Rubbing has more to do with rim size and offset. Do you rub at all now with weight in the back when you hit dips and bumps in the road? If so you will rub lowered. If not you will be fine.
Old Aug 21, 2012 | 03:24 PM
I think he has 20's with to tall of a profile tire so it probably will be a problem once he lowers his car.
Old Sep 14, 2012 | 06:29 PM
ibs's Avatar
ibs
I didn't want to make a new post but is it a bad idea to cut the original own springs on the car to drop it temporarily? You to see how I like it low?
Old Sep 14, 2012 | 06:32 PM
jjashaa's Avatar
Avant Garde Wheels
dont do it.
Old Sep 14, 2012 | 06:34 PM
03tLsNBP's Avatar
MechEng
better solution: fill the trunk and engine compartment with cinder blocks.
03tLsNBP's Avatar
MechEng
or find 5 very fat friends.
Old Sep 14, 2012 | 06:38 PM
Skirmich's Avatar
Cutting OEM Springs will Destroy them for Good and they will become wothless for Sale/Trade...
Old Sep 14, 2012 | 10:18 PM
fsttyms1's Avatar
Its a VERY bad idea.
Old Sep 14, 2012 | 11:21 PM
I would never do that, especially with how many images there are out there on the Internet of people lowering there cars. I would just goto google images type in Acura tl and then the spring you want and it will give you plenty of images.
Old Sep 20, 2012 | 08:08 AM
ibs's Avatar
ibs
Thats a big 10-4 thanks
Old Oct 1, 2012 | 10:48 AM
WdRg's Avatar
Do you need new shocks you can't put Teint on stock shocks ?
Old Oct 1, 2012 | 11:41 AM
Excelerate's Avatar
Former Sponsor
You can put TEIN springs on stock shocks, if the stock shocks are in good condition.
davidspalding
17
Feb 18, 2011 05:54 PM
Fender Bender
May 14, 2007 04:38 PM
orgnlprankster7
May 5, 2007 07:10 AM
edsonfire
Jul 23, 2006 07:43 PM
dcarlinf1
Aug 4, 2004 11:31 PM
