Which scanner programmer to get
Old Feb 29, 2020 | 12:43 AM
Caseylore's Avatar
I need to know which sxanner u guys recommend ty
Old Feb 29, 2020 | 02:22 AM
Karanx7's Avatar
Unregistered Member
Not sure what a sxanner is
Old Feb 29, 2020 | 06:49 AM
Caseylore's Avatar
Diagnostic scanner bro but i gt it worked out
Old Mar 1, 2020 | 09:17 AM
Iggy's Avatar
What did you end up getting Casey?
Old Oct 19, 2021 | 02:52 PM
KorzaFox's Avatar
I'm interested as well in what you ended up getting. currently looking as well and so far have the iCarsoft CR Pro on the top of my list.
Old Oct 19, 2021 | 02:55 PM
the main thing you want to look for in a scan-tool(Not to be confused with a scanner) is that it's bi-directional..
meaning; you can read and write DTC's.
which the iCarsoft CR Pro can activate the actuators, like the ABS module, throttle body actuator, SRS(airbags)...etc.
one does not want a scanner that can only read.
I recently bought a "Launch X431" because I had ABS issues. the scan-tool was able to read the DTCs and actuate the ABS module.
I never knew the iCarsoft CR Pro existed, it is a little bit cheaper than the Launch X431
Old Oct 19, 2021 | 05:26 PM
KorzaFox's Avatar
Thanks for the info. I only found iCarsoft after digging through multiple YouTube reviews and found one comparing Autel and iCarsoft.
Old Oct 19, 2021 | 05:36 PM
^if you're okay with the $300-400 price tag, try the iCarsoft out!
I could not justify the price of an Autel or a Snap-on Scan tool, as I am just a DIY. If I owned a shop, i'd def would try the Autel.
just curious; what are you trying to diagnose?
Old Oct 20, 2021 | 06:59 PM
KorzaFox's Avatar
^Hopefully nothing for awhile. I'm getting it basically for if anything happens that I would need it.
Blazing GT
May 3, 2008 09:55 PM
synth19
Dating & Relationships
Sep 8, 2005 10:19 PM
guavawang
Jun 16, 2005 11:48 PM
lothian110
May 26, 2005 01:26 PM
lovepo9e
Jun 10, 2004 07:37 AM
