Rims hurt Tranny????
Old 04-05-2006 | 03:26 PM
Hitlayers's Avatar
True or False????????
Rims that are bigger then factory put extra strain on tranny causing it to give in faster.....
Old 04-05-2006 | 03:29 PM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
false, way false. besides, just because they're bigger doesn't mean they're heavier. the problems with our trannies is a design problem. there's nothing you can do to stop it or speed it up (within reason). it's a roll of the dice really.
SSTS
Old 04-05-2006 | 03:57 PM
fsttyms1's Avatar
Actually Its true to a point. The bigger the rim the more weight that gets pushed outward (unsprung weight). it will make it slower and handle worse (there are exceptionns but not many). But as for hurting the tranny no. the amount of added stress would be null. (and if your worried about it making the TL trannie die faster NO.
Old 04-06-2006 | 06:52 AM
ChairmanMaoSaysRTFM
100% true in the world of kinematics, but Hitlayers also needs to remember that there are tolerances figured into every car design. hence why almost every auto manufacturer doesn't see it as an issue to offer 17" alloys as an upgrade over the generic 15" standard wheel.
SSTS
Old 04-06-2006 | 07:30 AM
NSXNEXT's Avatar
I would say that could be entirely true.
If you had a very low offset, say +30, the center point of the wheel would be much further out on the axle putting more stress on them, as well as the suspension, thus potentially putting more stress on the tranny.
Old 04-06-2006 | 07:54 AM
MikePA's Avatar
Larger, or smaller, wheels also change the effective final drive ratio which could cause tranny issues.
Old 04-06-2006 | 04:51 PM
ChairmanMaoSaysRTFM
i'm still gonna say no to his initial question because i think we're really pushing the limits here. what you're all saying is true about changing stresspoints and increasing torsion on your axles, but you're not going to degrade a tranny on a vehicle by changing wheel size unless it's from obscene weight increase because you added 30lbs on each wheel from putting 25inch rims on them.
how many of you ever seen a car with a busted tranny because a person put on 20s instead of 15s? i know i haven't. and a 15mm offset change isn't going to drastically change the MOI on your control arm and destroy your suspension either. these are *engineered* pieces made to withstand stresses and strains over what the vehicle can provide. if you're suspension and axles were that fragile you would bust something every time you went "curb hopping" or hit a pothole. think about it.
i wouldn't be concerned about larger rims changing your final drive ratio. most people get thinner tires to complement larger rims anyway. of course this is another set of problems on it's own if you live in an area with bad roads.
i'm willing to concede that you guys could be completely right, i just have to say i've never seen any hard evidence to point that way.
SSTS
Old 04-06-2006 | 08:43 PM
PenancE's Avatar
either way OUR TRANNY IS SHIT, NO WAY OF AVOIDING IT.
Old 04-06-2006 | 11:12 PM
ChairmanMaoSaysRTFM
sadly true. and i suppose this is really the focal point of the whole thread....although personally i don't worry about it too much. only when i think about buying the supercharger....
SSTS
Old 04-07-2006 | 03:39 AM
PenancE's Avatar
hey lets all donate 5 bucks too fsttyms1, so he can buy the SC and try it out on the 6 spd......first of our kind....our creation LOL
kev87a
11-02-2015 07:40 AM
Gout
11-02-2015 12:22 AM
kev87a
10-18-2015 02:03 AM
dirleton
20
10-16-2015 01:48 PM
xsilverhawkx
10-05-2015 11:00 AM
Quick Reply: Rims hurt Tranny????
