Replacing stock horn
Old May 10, 2010 | 10:06 PM
spoiler900's Avatar
I got a 2001 Tl, the stock horn sounds so wimpy. Its not very loud either. I honk at people on the freeway if I need to and it seems like they can't even hear me. I sometimes can't even hear it if my radio is on loud. Maybe replace it with a regular horn, a normal sounding one like the new 09+ TLs have, they sound nice. Anyone know of a link to buy one? Also easy to do it yourself? Thanks!
Old May 10, 2010 | 11:26 PM
phee's Avatar
I got the Shifts
my horn is louuud
Old May 11, 2010 | 12:25 AM
FlacoJ's Avatar
u need a forty caliber horn! it make a BANG! not a wussy beep
Old May 11, 2010 | 01:48 AM
thinhthan's Avatar
put a train horn on lol
Old May 11, 2010 | 04:32 AM
. N B P .'s Avatar
Nighthawk Black Pearl
get some Hella Horns
Old May 11, 2010 | 07:29 AM
spoTLess's Avatar
I thought of doing this myself too, I'm planning to replace it with a higher pitch one plus relocate it on the front. Other honda's horn should work, and it should be cheap.
Old May 11, 2010 | 05:02 PM
piggylover1985's Avatar
You can get one of the junk yard from an older Lincoln or Caddy for like 5 bucks, they came two in one.
Old May 11, 2010 | 06:10 PM
friesm2000's Avatar
B A N N E D
you mean an air horn, but yes and here you go: http://www.buellairhorns.com/
Old May 11, 2010 | 09:47 PM
sexyTLbeast's Avatar
8th Gear
haha
Old May 12, 2010 | 12:03 AM
spoiler900's Avatar
hahah i would so put a train horn on if it wasnt to much. Anyone know of a cheap train horn? (Like under 100 bucks). Or link to a regular horn will do. thanks!
Old May 12, 2010 | 03:54 PM
02type-s's Avatar
-Arsenic-
www.hornblasters.com
Old May 12, 2010 | 05:59 PM
Joe Foe from Buffalo's Avatar
I have a set of train horns that I'm planning on installing this summer behind my front bumper in a way you will not be able to see them on my 2005 TL with a custom bracket I need to make/fit. I eye balled it and measured the room in that area and they should fit. I will have a small compressor in the engine bay and run air lines to a five gallon air tank I will have in my trunk. I also plan to have it hooked up in a way that I will be able to hit a switch to arm it and be able to use my stock horn switch in the steering wheel. This post may help on this topic.
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/train-horns-gen3-753395/
Old May 12, 2010 | 07:57 PM
friesm2000's Avatar
B A N N E D
https://acurazine.com/forums/showthread.php?t=753395
wow that thread was last year
but anyways you need an air ride system to go along with that horn though lol
Old May 14, 2010 | 04:47 PM
spoiler900's Avatar
ok, is there a do it yourself thread, i dunno how to change the horn out
Old May 14, 2010 | 06:00 PM
friesm2000's Avatar
B A N N E D
look for how to pull the front bumper off in the DIY section, horns are right there behind the grill/bumper
Old May 14, 2010 | 06:44 PM
The horn off my 99 locates right behind the grill, pop the hood, remove the black plastic cover in top front of the radiator, and the horn is right there.
Old May 14, 2010 | 06:49 PM
friesm2000's Avatar
B A N N E D
02-03 you gotta pull the bumper, cause the grill is attached to the front bumper, instead of being on the hood itself, either way not very hard to get to, just gotta pull a panel or two off to access it
Old May 14, 2010 | 11:20 PM
Gotcha.
Old May 14, 2010 | 11:22 PM
He's an 01 though, is it the same location as 02-03 ?
Old May 14, 2010 | 11:37 PM
friesm2000's Avatar
B A N N E D
same location, at least the same general location/area if not the exact same horns and mounting locations between the two
Old May 15, 2010 | 02:11 PM
spoiler900's Avatar
ok thanks...easy to do...i no almost nothing about the engine of my car, is it just unplug and replug? im sure theres more to it i hav no idea
Old May 15, 2010 | 02:16 PM
friesm2000's Avatar
B A N N E D
plug and play, depends on what horns you are using, cause unless the new one is from an acura or a honda, it won't be plug and play, but then again not that hard to wire up though, two wires to each (and they are both the same on both horns), on power/switched/signal wire, and ground
also getting the wire/connector with the new horn would really help to in being able to wire it up easily
jblessing
Aug 8, 2018 09:43 PM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
HOWELLiNC
3G TL Photograph Gallery
Sep 17, 2015 10:04 PM
yahelou
Sep 6, 2015 09:12 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
