removing the resonator
Old Aug 20, 2007 | 08:42 AM
pjoseph's Avatar
Is this a good idea on a stock tl if yes are there any pics of what it looks like
i know it is behind the front bumper.
thanks
Old Aug 20, 2007 | 10:43 AM
sistom's Avatar
pwnage
Get either a CAI or SRI
Old Aug 20, 2007 | 03:01 PM
AcuraDreamin's Avatar
2000 Acura TL
sistom is right, cai is definitely the way to go, but im way too poor right now to be dropping like 150-300 on an intake, so i just took of the intake resonator for a little muscle sound for the time being. Im pretty new when it comes to mods, but it is really easy to take off the bumper, just a few tabs and screws and then the resonator is on the very left side of the car, below the air filter, there are two bolts that are holding it in place, quick and easy mod.
You might want to search for this, i found a lot of info on this mod searching.
Old Aug 20, 2007 | 03:21 PM
fsttyms1's Avatar
Do a search for removing the resonator. Plenty of info on it. I would remove it and get a K&N filter
Old Aug 20, 2007 | 07:24 PM
blackuraTLS's Avatar
What does this mean? Will it give me more power and will it hurt anything?
Old Aug 20, 2007 | 10:25 PM
fsttyms1's Avatar
the resonator is just that. A resonator. It keeps the intake quieter. It should as it removes the air restriction, No
Old Aug 21, 2007 | 12:34 AM
Right....so it will make it louder...and give me more power? Sounds good to me.
Old Aug 21, 2007 | 08:43 AM
fsttyms1's Avatar
only under WOT will it make it louder. The resonator is there because what VTEC does to the intake pulse is loud.
Old Aug 21, 2007 | 02:25 PM
oh i see, well i can always put it back on. How long do you think it will take? Are there pics of what i am looking for. I just recently removed the facia to install a new igniter for my passenger side hid. i am familiar with the front end as far as that goes. and uh....what does WOT stand for?
Old Aug 21, 2007 | 02:58 PM
02TLSfan's Avatar
Prick of the month
Finally a question about an acronym that I can answer. It stands for Wide Open Throttle, I had to ask this a while back as well, basically when you hit the VTEC.
Old Aug 21, 2007 | 03:50 PM
ohhhhh i see. haha.
Old Aug 21, 2007 | 04:39 PM
fsttyms1's Avatar
yes, remove the bumper. you will see the big black box on the drivers side. remove that.
Old Aug 22, 2007 | 01:41 AM
Got it! it sounds simply amazing.
Old Aug 22, 2007 | 08:21 AM
fsttyms1's Avatar
figured you would like it. Most do. Now if you want it louder, cut the bottom of the air box open to allow more air in. and remove the small resonator and replace it with a hockey puck or like i did a pvc end cap.
Old Aug 23, 2007 | 12:37 AM
what do you mean? whats the puck for or whatever you use pvc...whats that for?
Old Aug 24, 2007 | 07:33 AM
pjoseph's Avatar
I removed my resonator yesterday pretty simple to do. I now plan on putting a K&N filter in, also thinking about connecting a pipe to that rubber piece to extend it lower.
I dont want to cut the bottom of the box open just incase i sell the car.
Old Aug 24, 2007 | 08:11 AM
fsttyms1's Avatar
well if you remove the small resonator you will have a giant unfiltered hole. You need something like i described to plug it
Old Aug 24, 2007 | 08:15 AM
fsttyms1's Avatar
you can always epoxy it back together, or buy a new one for 42 bucks
Old Aug 27, 2007 | 06:29 PM
pjoseph's Avatar
Well i took off the resonator a few days ago and changed to a K&N air filter... sounds pretty good.
Also I am noticing much better gas mileage im at 175 mile with a half a tank left and i have been driving harder then usual just because the sound is still new to me. Usually i get around 300 per tank.
So for about 20min of work and $45 dollars i think it was well worth it.
Old Aug 28, 2007 | 03:05 PM
Blue_TL's Avatar
This is a great cheap mod. I did it and I loved it...later when i could afford it, i stepped up to an icebox and i don't regret it one bit...
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
dainmezron
Oct 16, 2015 06:56 PM
eastsideride
Oct 15, 2015 04:26 AM
merc009
Sep 29, 2015 03:06 PM
Rcelestino93
Sep 23, 2015 10:01 PM
