Performance page
Old Aug 25, 2006 | 09:08 AM
2ndgentl's Avatar
Performance page
A few things to look at for getting started with a performance plan. You might be in a different category so read which one you will be in.
Make sure to view this page in a full alone screen.
Levels Stage I Stage II Stage III Stage IV Stage V Stage VI Stage VII Gains
Free Home-made Plan Home Made intake and K+N
2-5hp Hand Port and Polish exhaust ports
1-2hp Polish Throttle Body
1-2hp Advance Timing
1-3hp Hollow Cat / Weld-In Test Pipe.
2-5hp Remove Power Steering Belt
2-3hp 9hp-18hp
Hidden Performance
$2000-6000 Drop In K+N Filter $80
2-5hp Throttle Body $250
4-6hp Extrude Hone the Stock Header
$200-400
3-4hp Test Pipe/HF. cat/ Or hollow $100-300
5-10hp 1.6L Dohc VTEC can upgrade to a 1.8L Bottom end
$1000
More hp/tq Race Head
$500-4000
5-50hp Hidden Nitrous System
$500-800
25-75shot
55-175hp
Cheap Plan
Cost $400-700 Cheap Intake $100
5-8hp Nice Header $300
7-9hp Throttle Body $250
3-6hp 15hp-24hp
Simple Plan
Cost $800-1200 Cold Air Intake $230
8-10hp Race Header
$420
9-13hp Exhaust
$400
8-12hp Throttle Body $250
4-6hp 27hp-31hp
Budget Racer
$1300-2200 Cold Air Intake $230
8-10hp Race Header
$420
9-13hp Exhaust
$400
4-6hp Underdrive pulleys $250
4-5hp Cam Sprocket $250
2hp-5hp. 31hp-51hp
Street Monster
$2500-5000 Turbo Basic $2500-4000
70-110hp Test Pipe/HF. cat $100-300
5-10hp Exhaust
$420
10-15hp Throttle Body
$250
6-10hp Underdrive pulleys $250
6-8hp Cam Sprocket $250
5hp-10hp Wires / Spark Plugs $150
2hp-4hp 104hp-167hp
All out race
Cost 10,000-???? Custom Race Turbo
$4000-9000
200-400hp Electronic / Fuel Race Ignition
$800-2200
10-30hp Custom Race Exhaust
$800
12-20hp Race Intake Manifold
$800-2500
25-60hp Race Head
$1200-3000
20-80hp 267-590+
These plans are just for helping you figure out which way to go. How much horsepower to expect and perhaps what category restrictions you might be limited too. For the hidden performance its for those that want to either look stock for just fun or to hide it from the dealer or anyone else. These results might not be exact , but these are tried and true real world prices and dyno's that provide the info. Also the parts used are just some of the parts that can be used. Of course there's more to add on to some or some can skip some and use some of there own. These parts were selected by there availability and popularity. More exotic parts and others weren't used since they basically don't do much or are really hard to get.
As For Suspension Goes its simple....pay more handle better.
Suspension Plan Spring Only
$100-200 Spring and Shocks-Non Adjustable
$400-800 Spring and Adjustable Shocks
$700 Coil-Overs
$1200-1500 Full Race Coil-Overs
$1500-2200
Explanation - About the suspension changes and difference in levels. Quick easy install , some kits lower too much for looks and you get a unsettled ride which isnt good for high speed bumps. Stock shocks will soon go. Now you have something to work with , even though they might be out of synch. This one you have a lot more to work with , you can adjust the shocks at least to try to match the springs and the car better. Yet still probably wont have a lot of travel, and you might just get a product that doesnt go well together These systems if really made for your car handle the best can be tuned like the stageIII but also have a bit more spring rate, ride height and travel. Which can help a lot. Street / Drag or Course Again just like stage IV but probably a higher known competition name or perhaps the shocks will have their own reservoir....which sometimes are controlled electronically from the car.
Brakes , bigger better stronger....pay morestop quicker.
Braking Plan Sports/Race Pads Only
$100-200 Pads and Rotors
$400-800 Sport Brake kit
$700-1000 Race Brake Kits
$1100-1500 All out race.
$1500-2000
Explanation - About the brake changes. Upgrading to more efficient brake pads, some might cause some sound or more brake dust so watch out. Slotted Rotors are suggested for Street Cars and race pads will do. Just make sure their not some crazy kind that need to be real hot. Also good to add race/dot4 brake fluid. Great for the street, possible new caliper, might need bigger rims. If your not really going fast then this might be overkill, but then again you might like safety. Also consider changing lines. Made for high heat all the time applications , more emphasis on cooling and anything to do to slow down. This is because on the track you are on the brakes a lot. The street you brake a bit and then cruise. Just like before but Anything from really oversized rotors & dual calipers .To materials made to handle anything. These kits will make any street tire the bottle-neck for braking faster.
[mod edit] No links to competitors sites please.
Old Aug 25, 2006 | 09:12 AM
2ndgentl's Avatar
2ndgentl
Ok, the page didnt come out as clear as I thought it would. Better yet, go to www. and click on PERFORMANCE. Neat stuff.
Old Aug 26, 2006 | 08:41 AM
ryebreadisme's Avatar
Low and Slow
these seem like decent pointers and mod suggestions. I was confused at first while reading but then understood what you were doing. "5-10hp 1.6L Dohc VTEC can upgrade to a 1.8L Bottom end $1000" what is that about? And are the high prices at the end of each section a total? Thanks.
Old Aug 26, 2006 | 11:48 AM
blk2001tlon19s's Avatar
318whp/289wtq @ 6psi
cool, I'm currently working on Stage VIII
Old Aug 26, 2006 | 07:29 PM
adamlee05's Avatar
Thread Police Chief
looks like he copied this from an integra forum and it is confusing as hell. the "stages" make no sense, that or im just missing something
Old Aug 26, 2006 | 09:37 PM
MikePA's Avatar
No, you're not missing anything. The post was designed to impress, not inform. It's not worth the time trying to understand it.
Old Aug 26, 2006 | 10:41 PM
sbuswell's Avatar
I need 2 more gears
this doesn't amke any friggin' sense. mods please lock this thread so no members waste their time reading this nonsense.
Old Aug 27, 2006 | 12:25 AM
PenancE's Avatar
yea wtf is the point in this thread? we need a noob to tell us how much the gains are when we alrdy know of it?
Old Aug 27, 2006 | 12:46 AM
Phesto's Avatar
I am glad I'm not the only one wondering what the point of this is.
Old Aug 27, 2006 | 01:13 AM
adamlee05's Avatar
Thread Police Chief
Old Aug 28, 2006 | 02:48 PM
MrAlex's Avatar
99 SSM Tl
Old Aug 29, 2006 | 06:21 AM
2ndgentl's Avatar
2ndgentl
Yeah, Sorry, after I had copied and pasted it from another website where it is 100 times easier to understand it I had the website posted on this page, but they deleted it for the competition.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
San Yasin
Sep 29, 2015 10:52 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
