Nitrous Question
Nitrous Question
What can safely be run through the J32A2? I don't want a big shot, 75 at max. Is this safe if not used a lot?? Nitrous guys help me out, this is an area I haven't messed with before and I don't feel like blowing anything up. Thanks!!
ive been running a 65shot fine. lost my 75 shot so i bought a hundred shot and thats when i was running lean. ill tell your that your gonna blow your trans faster bc of the extra stress on it, but its hella fun.
There are quite a few members that run Nitrous and haven't had problems. Excelerate (the vendor) has helped install at least one nitrous kit for a member. They had good results. Maybe he can give you some info.
Originally Posted by Rajca
btw what kind of nitrous system r u gonna run. NOS, ZEX, XS,... and is it gonna be a dry shot or wet shot.
since i know more about nitrous id go with a wet shot bc u dont have to worry about fuel since it shoots nitrous and fuel together but is also more work to get it working
I agree with Rajca on the wet kit option, you'll have a less likely chance of running lean, Zex makes a very beginner friendly wet kit, less things to mount and wire, but the other companies are great as well, start off with a 50 shot and then gradually move up in hp to find the best compromise between hp gains and engine/ tranny longevity, either way the more power you make the more things will break
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
