Need to replace exhaust
Old Nov 30, 2010 | 04:10 AM
QWKLIL4's Avatar
4th Gear
A while ago, I accidentally backed into a taller curb with my 03 TL-S. The impact pushed the muffler back towards the front of the car, which in turn somewhat crimped the piping on the passenger side exhaust. The "crimp" is before the muffler flange, but after where the piping splits from 1 into 2 sections. I need a new muffler obviously, as it eventually cracked at the weld and literally fell off. I'm probably going to need a new "mid" pipe as the current piping on the car is bent from the impact. I'm sure this will cause the muffler to sit at an angle and not allow the hangars to be connected to the undercarriage.
My question is this. I found THIS site, http://www.racepages.com/parts/muffler/acura/tl.html, and was curious if I could use these exhaust pieces? Specifically P/N: REPA961131 and P/N: REPA961133. I'm sure the "mid" pipe will work just fine. But what about the muffler? I was told the TL-S uses special mufflers not shared by the base TL. This site lists the muffler for all TL's (including the Type S).
Any thoughts, opinions? The car is staying bone stock. No aftermarket exhausts are an option. Thanks.
Old Dec 2, 2010 | 11:53 PM
QWKLIL4's Avatar
4th Gear
Anybody have any input?
Old Dec 3, 2010 | 12:09 AM
03tLsNBP's Avatar
MechEng
well the TL-S has bigger piping than the TL-P. 2.25" vs 2". so if you find an OEM style muffler you could just take it to an exhaust shop and have them replace the piping thats damaged, instead of replacing the entire exhaust. they can also properly adjust it so that it attaches to the hangers and sits level with the bumper.
Old Oct 17, 2011 | 10:17 PM
ronrecr_RENAMED's Avatar
ronrecr
I went stainless steel custom at Lous exhaust...great job went cat back 2.75 all the way back with two straight through mufflers..had to add a resonator because of the drone..sounds great and gained 50 miles to a tank of gas.. and a noticable bump in hp. I have a cai also..I always travel the same every week ...I am quite happy
Old Oct 17, 2011 | 10:39 PM
03tLsNBP's Avatar
MechEng
^ got sound clips?
jspangan
ILX
Aug 18, 2020 11:05 AM
ExcelerateRep
Sponsored Sales & Group Buys
Jan 6, 2016 09:59 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
IIDXholic
Oct 8, 2015 07:53 AM
