need an intake. can u help?
Old Mar 18, 2007 | 02:14 PM
ACURA`TL`TYPE-$'s Avatar
hey, sup. I have decided to get an intake (preferably AEM cold air) but short ram will do too. i was wondering if anyone of u fellas knew wher i could get one cheaper then the over priced once online, or if anyone selling some plz let me know. thks
Old Mar 18, 2007 | 02:35 PM
reugal vs. V2 aem intake
BY the way one more question what is the diferens between the regular 180 dollar cold air AEM intake and the V2 version. is it more HP, gas millege?
Old Mar 18, 2007 | 03:02 PM
RidinDurty's Avatar
Check this out
https://acurazine.com/forums/sponsored-sales-group-buys-10/injen-cold-air-intake-groupbuy-cl-tl-tl-04-tsx-317087/
Excelerate is one of our best vendors here at acurazine. If i were you i would stick with Injen. He sell s them pretty cheap. If i had an 02' like you i would have gotten an Injen intake. He sells the Cold Air Intakes. They give you more HP than the Short Rams.
Also check out the Private Sells & Trade section
https://acurazine.com/forums/non-automotive-motorcycle-sales-9/
maybe you could find something for a good deal there. Those are usually used parts but you never know what you may find.
Old Mar 18, 2007 | 03:04 PM
RidinDurty's Avatar
oh yeah if you want you could go with ebay if you can't really find anything. I bought my AEM Cold Air intake used on ebay for $65. I re-painted it, changed filter and saved me a lot of money
But like i said, if i had an 02' i would definitely go with Injen, not AEM.
Old Mar 18, 2007 | 04:14 PM
Mike_McCready's Avatar
my AEM has a cracked mount, which seems to happen to most people with the AEM CAI
Old Mar 18, 2007 | 04:34 PM
6MTUA5's Avatar
No He Can't
There is a new vendor Autoworks that is making custom intakes for our TL's. He just had them dynoed and put up the results on his thread. Don't know how much power they make compared to Injen or AEM, but I'm sure that they will be cheaper.
Old Mar 18, 2007 | 04:55 PM
01tl4tl's Avatar
Buy from our sponsoring vendors whenever you can
A short ram is ok but does not bring actual "cold" air in to the system
Old Mar 18, 2007 | 04:58 PM
6MTUA5's Avatar
No He Can't
Autoworks thread https://acurazine.com/forums/showthread.php?t=154923
Old Mar 18, 2007 | 08:37 PM
02type-s's Avatar
-Arsenic-
The V2 uses a dual chamber design (using two different diameters and lengths of piping) that creates multiple frequency sound waves that claims to produce the largest area under the curve of any intake system on the market. The sound waves help charge the cylinders with more air throughout the entire rpm range and are what makes the V2 to outperform a regular cold air intake. I havent tried the V2, I had an Injen Race Division cold air on my last car and liked it, so I havent decided what to use yet. Well, I hope This helped!
Old Mar 18, 2007 | 08:45 PM
02type-s's Avatar
-Arsenic-
Thumbs up
www.nopionline.com I have ordered loads from this place with previous cars. Good prices and fast shipping. Also try www.autocarparts.com
Old Mar 18, 2007 | 08:56 PM
twighunter00's Avatar
Has anyone else had problems with AEM. I am looking to get a Cold Air Intake and was pretty much sold on AEM, but is Injen that much better? They're very very close in price so who's had better performance from what?
Old Mar 18, 2007 | 09:01 PM
fsttyms1's Avatar
And i would place money on those who have had the mount crack isnt from a problem with AEM, but a bad motor mount.
Old Mar 18, 2007 | 09:50 PM
RidinDurty's Avatar
Well i have a AEM CAI and so far (about 2 months) i have no complaints. I wanted Injen but couldn't find any that fit the 99-01 TL-P.
Old Mar 18, 2007 | 11:15 PM
6MTUA5's Avatar
No He Can't
I've needed to get new mounts for a while. I probably should before getting new intake and headers, huh? Who should I contact for those? There are 3 right?
Old Mar 18, 2007 | 11:18 PM
02type-s's Avatar
-Arsenic-
If that was true, then Injen would also be notorious for breaking mounts. Seeing as though they do not have that reputation, I would have to disagree with you and say the AEM clearly has weaker mounts.
Old Mar 19, 2007 | 08:14 AM
fsttyms1's Avatar
where does the injen mount? Also i have one that i made out of steel and i have cracked mine 3 times now because i have a bad mount. I know mine isnt a weak mount, but i know i have a bad motor mount. If the motor can move enough it will tear it off teh side of the intake. AEM uses aluminum and where its attached it can cause it to rip it off just like mine has due to the motor mount being broken. Also the ARM isnt notorious for breaking. there are FAR more with them with 0 problems than those who have had them break.
Old Mar 19, 2007 | 10:17 AM
02type-s's Avatar
-Arsenic-
The Injen uses the same mount location as the AEM. The Injen uses a rubber shim, which allows it to move a little.
Old Mar 19, 2007 | 06:11 PM
fsttyms1's Avatar
Either way id still bet it has to do with a broken motor mount. Like i said ive torn a hole in mine (which is thick metal) 3 times now due to me having a bad front motor mount already.
Old Mar 19, 2007 | 07:27 PM
meimei's Avatar
Agree. have not tried V2 either. i had AEM acura intake and it works well too... I think there are more realted threads that can be useful.
Old Mar 19, 2007 | 07:31 PM
Hockeyman's Avatar
slobalt defender
the v2, however, is only for the premium model, it won't fit the type S. I have one and i love mine, the sound is amazing.
Old Mar 19, 2007 | 08:01 PM
02type-s's Avatar
-Arsenic-
^^ true, I want the Injen Race Division anyways
Old Mar 19, 2007 | 08:04 PM
02type-s's Avatar
-Arsenic-
Are you using a rubber waher or insert? If not thats why its tearing holes. It has to be able to move, even if your mounts are brand new the motor is gonna move a little. Try a half inch or 1 inch thick rubber insert with a longer bolt where it mounts up. You wont tear any more holes.
02type-s's Avatar
-Arsenic-
Are you using a rubber washer or insert? If not thats why its tearing holes. It has to be able to move, even if your mounts are brand new the motor is gonna move a little. Try a half inch or 1 inch thick rubber insert with a longer bolt where it mounts up. You wont tear any more holes.
Old Mar 19, 2007 | 08:21 PM
02type-s's Avatar
-Arsenic-
By the way, I'm not trying to be a dick, I'm just trying to help you stop tearing up your intake.
Old Mar 19, 2007 | 09:02 PM
fsttyms1's Avatar
Its got a rubber insert, and it can move. And the motor mount was new when i did the 6 speed swap but that was 20k miles ago and it has since been destroyed by the motor. My motor really moves around. I know the motor moves a little. but if it moves to much to quickly it will slowly tear the mount off the cai (as is the case with mine and most likely the others who have had this problem)
Old Mar 19, 2007 | 09:22 PM
Souped's Avatar
i ahve the v2...had to get it modded to fit the type s but its great
Old Mar 20, 2007 | 09:03 PM
So its the Regular AEM CAI for the TL-S or an Injen Race Division series? I'm just kinda waiting for some checks to come in the mail and than probably will be ordering so just trying to figure this out I'll be doing searches, don't worry, to get all the info, but I'm interested in getting opinions of people who have these products nad have gotten em recently
Old Mar 21, 2007 | 11:20 PM
02type-s's Avatar
-Arsenic-
You would have to modify the V2 to fit the Type-S. AEM makes a regular cold air and I believe a short ram, and Injen makes short ram, cold air, and Race Division cold air. Im going with the Race Division cold air, I had one on my last car and loved it.
Abe_Froman
Sep 16, 2015 01:27 PM
scalbert
Aug 26, 2008 04:25 PM
civicsmoker
Sep 27, 2004 02:45 PM
SJ Silver Type-S
May 18, 2003 12:28 AM
Darivative
Jun 22, 2002 01:21 AM
