in need of help finding a few parts if anyone can help
4th Gear
i drive a 02 tl-s with i/h/e im trying to add a few more mods.
i was thinking pulleys, bigger fuel injectors, spark plugs and maybe a cam upgrade if it has been done. all opinions welcome im new to the site jus lookin for some direction. any brands suggested??????????? n e other mods suggested????
Unorthodox makes a pulley set. Alternator, P/S, crank. You can get stock or underdriven, only underdrive if your stereo is 600w or less. Someone told me to get spacers which I guess go between intake and engine to help keep incoming air cooler. Plugs you should be using NGK iridium. Search the forum and you'll find exactly which ones to get. Haven't heard anything about a cam upgrade though, you'd have to ask someone a bit more well informed than I am. You could add a supercharger. Comptech makes one if you're really looking to make it go. Other than that I can't think of any more performance mods. You could always upgrade your exhaust to ATLP if you haven't already.
Unregistered Member
Don't worry about the fuel injectors. There is a Cam regrind from Bismoto, but IDK if it lasts too long. Some people say it's fine, while others say it's not.
You could also get a Option pulley from eBay, which is only about $30. It only comes in underdrive though.
4th Gear
thanks you guys all the help is appreciated il do some more research a little later tonite and let you guys know my next move on the hwip. n e links to these parts would also be appreciated
Avant Garde Wheels
yes.. tuo itrb
sounds like a plan.
lol.. xs-power makes a turbo kit but thats for the 6th Gen Accord
http://xs-power.com/acura-honda-turbokits-16.htm
iirc, there was a former member who bought that.. changed some of the parts and make slight changes to one or two of the pipes and voila.
sounds like a plan.
Like someone said, go FI or leave as is. Pulley, injector, even cam regrind are a waste on this engine and will NOT produce any power gains worth mentioning. With IHE you pretty much maximized the efficiency of an already efficient engine. Spending money on pulley and other BS which might net you extra 15 HP is a waste. If are serious about making car fast, take it to a performance shop and discuss what they can do for you when it comes to FI setup.
cycdaniel
12-17-2019 10:58 AM
