Need help deciding what to do with engine build
Old Jun 13, 2016 | 12:59 PM
prove_it's Avatar
So my base 02 is burning oil badly, rings are stuck. I work as a master tech at Honda, so as far as the work goes I can handle the build no problem. Now my big question is:
What should I build?
I have access to a J35A4 for 50 bucks, (sure not the toughest, but its 3.5)
A set of 05 RL cams,
the ability to port and polish the whole head setup.
Now what I want is a very strong daily driver that I won't need to worry about. To me the low end is far too sluggish, and the 3.5 sounds like a good ticket. Now if I go 3.5 could I use the RL cams as long as I use 07 type s springs? I've already swapped to an AV6 07 trans with 80k on it, so not too concerned with trans failure.
Or should I just p&p the heads, run rl cams, and keep the 3.2 bottom end and get some headers?
I'd rather not spend 500 on a J35a3 engine , since I really want to put fresh rings and bearings in the engine either way.
I have an SFAC I can make small adjustments to compensate for fuel issues.
Doing all the work myself and having parts at cost lets me play a little more without going broke.
Old Jun 14, 2016 | 09:50 PM
02tl-p's Avatar
Do the 3.5 swap with type s cams. Just my two cents
gavriil
Aug 20, 2025 04:43 PM
Black Tire
Dec 18, 2017 08:15 AM
gatrhumpy
Feb 23, 2016 07:39 AM
DJMikeT
Jan 6, 2016 11:57 AM
GK83
Sep 13, 2014 12:48 AM
