Motor mount performance
Old Jan 23, 2008 | 09:59 AM
2ndgentl's Avatar
Correct me if im wrong, but when you floor your car from a dead stop your motor torques up first then unleashes the power to the wheels. So........... What if you were to strap down the front motor mount where the motor throws its power directly to the wheels. Kind of like a solid mount.
Old Jan 23, 2008 | 10:08 AM
01tl4tl's Avatar
WHY?
there are solid poly filled mounts available if breakage is your issue
The stock mounts (depending on model/year) contain a special hydraulic type fluid oil AND have a vacuum powered assist system built into them as well.
Old Jan 23, 2008 | 07:52 PM
jjashaa's Avatar
Avant Garde Wheels
whoa, never knew motor mounts had some hydraulic thingy.. learnin something cool!
Old Jan 23, 2008 | 09:08 PM
fsttyms1's Avatar
I would just get the group buy mounts.
Old Jan 23, 2008 | 09:39 PM
NSXNEXT's Avatar
or do the window weld trick. Do a search.
Old Jan 25, 2008 | 06:06 AM
oulaw29's Avatar
Attorney- Will Sue 4 Food
Thumbs down
So what your saying is motor mounts add more hp or torque?
Old Jan 25, 2008 | 07:57 AM
2ndgentl's Avatar
2ndgentl
Torque. Its just like when your car has the stock springs and struts, from a dead stop if you floor your car the front end of your car lifts up high then takes off, But if your car is lowered it dont lift up as high making your car stiffer so it transfers the torque faster to the wheels.
Old Jan 25, 2008 | 08:22 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
i poly'ed my mounts but never dyno'd them so i don't know if there was a big difference. personally i couldn't tell. i went back to stock mounts before i had my transmission replaced last time in November. i may swap the front one back out in the spring with the poly filled one.
Old Jan 25, 2008 | 08:47 AM
fsttyms1's Avatar
It doesnt add more, but it helps permit better transmission of that power to the wheels.
Old Jan 28, 2008 | 03:33 PM
6MTUA5's Avatar
No He Can't
-- https://acurazine.com/forums/sponsored-sales-group-buys-10/innovative-mounts-groupbuy-2nd-gen-acura-cl-tl-376980/
Don't try and do all this crazy stuff with your stock mounts. They are weak.
Old Feb 9, 2008 | 11:57 AM
sorviu's Avatar
4th Gear
I want to know whats the correct performance mounts for my acura TL 00 if you can send me the link where can i shop to my email patjoyeria@yahoo.com
Old Feb 9, 2008 | 02:44 PM
6MTUA5's Avatar
No He Can't
The link is right above you.
Aug 15, 2019 12:58 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
wilztlxs
Dec 1, 2015 09:16 AM
Sep 17, 2015 08:57 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
