Egr Valve
Egr Valve
How do you clean the egr valve? Do you take it off and spray intake cleaner down the holes? Correct me if im wrong but it is mounted on the front driver side of the motor with two bolts holding it.
Hello.... Search.. here is a DIY
https://acurazine.com/forums/showpos...39&postcount=8
http://www.in.honda.com/Rjanisis/pubs/SB/B00-004.PDF
https://acurazine.com/forums/showthread.php?t=156252
all taken from the D.I.Y. section of this forums front page(2nd GEN section) that is stickied as the first thing you'll see.
2ndgentl
Thats cool I have already cleaned out my EGR PORT on the intake manifold, but im talking about the EGR VALVE. Its on the driver side towards the front of the motor, it looks like a solenoid brown in color with one clip with wires running to it and its held on by two bolts.
yea, you need to change the egr valve it self. i changed mine, its going to run you about $125.... make sure thats why your CES light is on because i changed mine with out cleaning out my ports and my light is still on.. i should have cleaned my ports 1st..
