May be a silly question but....
Old Mar 9, 2010 | 03:23 PM
Hitlayers's Avatar
Just had a quick question, like I said it may be silly, but I am detailing my car and as we all know when waxing and buffing it is hard to go between the ACURA logo and 3.2 TL logo, are these easily removable so I can wax the area? And if so I'm assuming it's just taking off the carpet on the inside of the trunk correct? Thanks!
Old Mar 9, 2010 | 04:36 PM
swoosh's Avatar
takin care of Business in
once off putting em back on will need GLUE or 3M tape or some like that !!!
Old Mar 9, 2010 | 04:51 PM
hANDYcaptd's Avatar
It's the Halladay season!
The word ACURA is taped on. You can remove but you'll need 3M tape to apply it back. The A is pinned on. This you can remove and put back easily I think.
Normally I just go around the word ACURA when I detail. I sometimes go in between the letters by hand when I wax though.
Old Mar 9, 2010 | 05:00 PM
dave_ramkumar's Avatar
2011 ZCP E92 M3!!
no, its just 3m glue tape that holds it on
Old Mar 9, 2010 | 05:49 PM
TheMegalodon's Avatar
I'm a thrill seeker in my
I tape off the emblems and polish the rest of the trunk.
Old Mar 9, 2010 | 09:41 PM
JCharged's Avatar
Just debadge it already.
Old Mar 9, 2010 | 09:52 PM
ANC297's Avatar
Bonki' Ehrite!
How does the emblem come off though? Is it just pinned on, so you carefully pry it off or it is screwed on, or what?
Old Mar 10, 2010 | 07:06 AM
99AcuraTL03's Avatar
is too sexy for his shirt
usually no one pulls off the A symbol just the acura lettering and the 3.2tl thing thats it
Old Mar 10, 2010 | 09:58 AM
swoosh's Avatar
dont just pull it off !!!!
take a hair dryer to it and take it off using a dental floss !!! now this applied to the ACURA and 3.2TL lettering and not for the A symbol !!!
Old Mar 10, 2010 | 10:55 AM
ANC297's Avatar
Bonki' Ehrite!
Yeah, I know that. But I wanna polish behind it. So does it just loosen out?
Old Mar 10, 2010 | 05:29 PM
myTLgoesBWAAH's Avatar
no dont do that, take a plastic spreader or something very thin and u will start to remove the double edge tape holding the ACURA on and thats all you need to do after that there might be some double sided tape left on the trunk, you can easily remove that with a rubber wheel or just take thinners to it, BUT make sure your trunk hasnt been painted before you use thinners lol, if it has just use degreaser and it should come off. for the A symbol clip puller and gently pry on one side at a time and it shuld pop off. VERY EASY!
Old Mar 10, 2010 | 08:49 PM
jaMezBOI's Avatar
philly flickin'
use a heat gun, heat it up and use fishing wire to run behind the badges. They all come off the same way, only difference with the A is that it has 2 aligning pins in it. They all are stuck on with 3M double sided tape
Old Mar 10, 2010 | 09:08 PM
mystakin's Avatar
B A N N E D
once you take off the letters i wouldnt both putting them back on. its a pain getting all the 3M glue off, took me a few hours in all. did it last weekend. was a pretty bad experience. if you are planning on taking it off set aside an hour or so, its easy but quite tedious.
Old Mar 16, 2010 | 03:53 PM
Hitlayers's Avatar
Thanks for your responses guys, I think I'm just going to wax around the letters, really isn't that serious....lol, thanks again guys!
Old Mar 16, 2010 | 07:29 PM
lol ANYTIME just here to help out
Old Mar 18, 2010 | 01:14 PM
Blamson87's Avatar
Just debadge...
Old Mar 18, 2010 | 09:34 PM
sbuswell's Avatar
I need 2 more gears
if you debadge then use Goo Gone to take off the remaining tape residue. DO NOT USE PAINT THINNER OR STRIPPER.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
