light problem
Old Jun 29, 2007 | 01:27 AM
3.2s-type's Avatar
light problem
i just recently black out my lights and i notice that my lighting looks different is this sopose to happend??? cuz i been on a CL with the oem black out lights and it doesnt look the same
i took it to Acura dealership service but they didnt seem to fix it.. the problem is that its level right when its in front of a garage door but in the night it mostly lights the front floor i say about a car a half head and from thier everything else is darker wich i dont remember doing that before.
if any of you guys know what might be the problem and know how to fix it please help.
Old Jun 29, 2007 | 01:53 AM
02type-s's Avatar
-Arsenic-
It would be easier to help you if you had a picture of your headlights. Did you paint too much of the housing reducing the reflection?
Old Jun 29, 2007 | 01:54 AM
01tl4tl's Avatar
So you had the headlight adjustment checked at the dealer- is that correct?
OK ,so when in front of the garage level- the main part of the low beam should be about 3 feet off the ground
Was there a reflector plate inside the housing that got disturbed?
Old Jun 29, 2007 | 10:15 AM
fsttyms1's Avatar
Is the bulb seated correctly?
Old Jun 30, 2007 | 12:02 AM
3.2s-type's Avatar
i just painted the same way a CL oem black out lights look [IMG]062107_0735 dont really know how to put pics in here
Old Jun 30, 2007 | 12:15 AM
3.2s-type's Avatar
i measured the main part of the low beam on a garage door and its bout 2 feet whent to acura dealer check out a 2000 TL (mine is a 2002)and it measured bout same hight talk to the techs about the lighting should be 3 feet of the ground they said NO WAY To HIGH so im thinking im going to do it myself.
so i back out of the garage door where is measured 2 feet..back out about 4 feet and the low beam was like 1ft or less of the ground.
i did stand on the light when i was on the process of sealing it back maybe that was a mistake
Old Jun 30, 2007 | 12:20 AM
3.2s-type's Avatar
good question not sure cuz i just try to get the Hid in there until the little wire that holds it stayed in place and stiffend the Hid bulb
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
brandnewcolony
Sep 12, 2015 10:39 AM
HeloDown
Sep 8, 2015 06:51 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
