J35a1 + j32a2 heads?
Old Dec 14, 2015 | 04:12 PM
justin676's Avatar
I have a j32a2 in my stock 02 tl-s. I found a j35a1 in an 01 oddessy, and was wondering if I were to build this engine first, would my stock engine mounts bolt up? And would the block fit? And second what other modifications would be necessary to make this work? I'm under the impression that I would need to use different piston heads? And third would this build be worth it if I can get the j35a1 engine cheep?
Old Dec 14, 2015 | 07:47 PM
Karanx7's Avatar
Unregistered Member
Yes
Yes
Nothing
No
Yes
Old Dec 14, 2015 | 09:22 PM
justin676's Avatar
Ok sweet! Are you seeking from experience? I'd really like as much info as I can get on this spacific combo
Old Dec 15, 2015 | 05:25 PM
Karanx7's Avatar
Unregistered Member
I'm doing something similar. I'm getting a J35A3 (pretty much same as J35A1) and swapping my J32A2 cams into it.
The only reason to swap the heads (instead of just the cams )is to get the 1mm bigger intake valves, but that just isn't worth the hassle to me (new head gasket and prepping the block).
You will lose a little compression using the J35 pistons though, not a big deal. Apparently the J32A2 valves WILL clear the J35 pistons, but I'm not worried about it since I'm only swapping cams and not the entire head with the valves.
Old Dec 15, 2015 | 06:55 PM
justin676's Avatar
You think the valves are the same length? I'd still be worried if the j32a2 cam lobes are larger than the j35's? Anyway thanks
Old Dec 15, 2015 | 07:35 PM
Karanx7's Avatar
Unregistered Member
That's not what I mean. The cams don't have anything to do with it.
It's the intake valve diameter that is bigger on the J32A2. So the notches on the J32A2 pistons are bigger to accommodate the wider intake valves. The notches are smaller on the J35A1 engine, but they should still clear the J32A2 valves.
Old Dec 15, 2015 | 07:37 PM
Karanx7's Avatar
Unregistered Member
https://acurazine.com/forums/second-...-heads-876803/
^Read this
tomnjen2
May 23, 2020 04:46 PM
grcat
1G CL Problems & Fixes
Aug 4, 2017 11:17 AM
brian6speed
Dec 19, 2015 07:56 AM
dinks07
Dec 12, 2015 08:35 AM
MikeekiM
Dec 10, 2015 12:34 AM
