J32A Upgrades for Nsx
Old Oct 21, 2014 | 06:33 PM
  #41
Skirmich's Avatar
^ Is that the crankshaft part no: 13310-RK2-A01 and Rods 13210-RK2-A00 ?
That does work too for a J32A2 right? Might sound like a stupid question since IIRC both use the same block.
Old Oct 22, 2014 | 07:08 AM
  #42
fsttyms1's Avatar
for the crank. I used 13210-RKG-000 for the rods.
Yes, it works for the J32A2 as well. It is the exact same block
Old Oct 22, 2014 | 05:51 PM
  #43
Skirmich's Avatar
^ All parts seems to be coming with bearings, Can you confirm this fatty?
Old Oct 23, 2014 | 05:00 PM
  #44
fsttyms1's Avatar
All parts from where? OEM? Bearings dont come with them. You need to match the code on the crank to the bearing color to get the right bearing for the rods. Same goes for the crank and the block. The block has 4 letters ranging A thru F i believe and you match that with the numbers on the crank to pick the right bearing.
Old Oct 25, 2014 | 04:18 AM
  #45
Skirmich's Avatar
Because in Hondapartsunlimited it shows the code number for the crankshaft with the bearings as a set in the picture?
Old Oct 25, 2014 | 08:29 AM
  #46
fsttyms1's Avatar
?? code for the set?? I dont see that anywhere. Look at the picture again. Then look at the parts list. #7 which is the rod bearings. There are 5 different bearings. They are by color. Look at the crank. There are 2 (9 and 11) different bearings, uppers and lowers. Each with 6 different colors to choose. You NEED to cross reference the stamped code on the block with the code that is stamped on the crank, whats shown are individual, you need 6 of each. Same goes for the rods. You have to take the code stamped on the crank for the bearings for the rods where you need 12 total.
Old Oct 25, 2014 | 08:40 AM
  #47
fsttyms1's Avatar
Oh, then once you get them (if they arent damaged from the stupid way they ship them) you need to plastigauge them to see that the clearance is correct
Old Oct 25, 2014 | 11:01 AM
  #48
Skirmich's Avatar
So in any case re-using our current bearings is better?
Old Oct 27, 2014 | 09:20 AM
  #49
fsttyms1's Avatar
No where would you get that idea? Get new.
Old Nov 7, 2016 | 02:38 PM
  #50
UncleDave's Avatar
Thanks for your great insight to the buildup you have. I have a 05 Tl, and looking to do a 3.7 stroke upgrade.
My question is this:
If I were to build my new motor using:
MDX 3.7L crank and rods, pistons
Bore block 1MM over to allow piston usage
Stock 05 Tl 3.2L heads
What type of Compression ratio have you seen using this setup? How high?
Or should I use the 3.7 heads?
Dave
mlody
Dec 4, 2019 02:11 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
kb1rl
Sep 30, 2015 10:17 AM
thegipper
Sep 28, 2015 01:01 PM
