Intake Resonator problem.
Old Feb 8, 2011 | 04:29 PM
wdmwilliams5's Avatar
Question Intake Resonator problem.
If I remove my intake resonator wont the pipe that was connected to it suck up things such as gravel, leaves, etc., as I am driving?
Old Feb 8, 2011 | 04:39 PM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
You must be referring to type-P where the intake resonator is attached to the intake pipe. What do others use to cover that hole?
Type-S does not have that issue.
Old Feb 8, 2011 | 04:43 PM
I have a 2003 tl-s so why will it not have that problem?
Old Feb 8, 2011 | 07:17 PM
fsttyms1's Avatar
The resonator is BEFORE the filter on BOTH cars below the filter and behind the bumper. The tl-p has a small one as well between the air filter and tb, and if you remove that one it needs to be plugged with something like a hockey puck. Most just remove the lower res
Old Feb 8, 2011 | 09:28 PM
01tl4tl's Avatar
if you need to plug that hole
iirc ziners have used a plastic white plumbing cap- slides in- hose clamp to make nice,,and enjoy
Old Feb 9, 2011 | 08:41 AM
fsttyms1's Avatar
Thats what i used.
https://acurazine.com/forums/showthr...ight=resonator
Old Feb 9, 2011 | 01:50 PM
03tLsNBP's Avatar
MechEng
OP -
you will have no problem sucking up anything. you have a splash shield that will block all large objects from getting into the airbox, as well as a filter to block any small particles from getting into the intake.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
merc009
Sep 29, 2015 03:06 PM
thegipper
Sep 28, 2015 01:01 PM
