intake performance questions
Old Apr 21, 2010 | 12:03 PM
  #41
DC3328's Avatar
Your Garage
Originally Posted by notbrant
Are AEMs known to make your motor shake violently or something?
yes, but with POWER!!
there have been some cases where the vibramount arm ripped off the tube due to excessive vibrations ie bad motor mounts
Old Apr 21, 2010 | 12:29 PM
  #42
Rajca's Avatar
wham bam thank you ma'am
If u have bad motor mounts than ur engine hase more movement and will rip the praket off from the intake pipe. The bracket is welded on the intake pipe and then bolted onto the chassis and their a rubber insert between the chassis and intake. But the bracket can still rip off.
Pease tell me u were joking.
Old Apr 21, 2010 | 01:04 PM
  #43
fsttyms1's Avatar
No, the reverse, bad mounts all the motor to move a lot and where AEM has their mount it tends to snap them off leaving a big hole in your CAI
Old Apr 21, 2010 | 02:24 PM
  #44
notbrant's Avatar
So my CAI seemed to not fit, i am not sure because the Type S has the secondary intake "stage" or whatever, I think thats the peice before the throttle body. But because of that, I had to shorten the end that connects to the engine or else It would not fit. It would be stopped buy the inner fender, and I also had to roll the metal behind the headlight housing, and also it wont bolt up to where the mount is supposed to. It's the correct part according to AEM.
Old Apr 21, 2010 | 02:33 PM
  #45
notbrant's Avatar
OK, cant edit, but here are photos.
Old Apr 21, 2010 | 04:16 PM
  #46
DC3328's Avatar
Your Garage
I'm 90 percent sure you bought a base model intake
  #47
assclown's Avatar
2000 acura tl FPR
i think that intake was for the TL-P. since you have the VSA TB there it's making it too long...
Old Apr 21, 2010 | 04:33 PM
  #48
notbrant's Avatar
Can i cut the pipe at the end of the AEM logo and put the bypass valve there?
This way it shortens it and make it fit properly.
either that or anyone wanna trade for a TL-S one?
Old Apr 21, 2010 | 04:40 PM
  #49
assclown's Avatar
2000 acura tl FPR
i wouldn't do that
best bet is to post WTT ad in BM
  #50
Rajca's Avatar
u can cut it by the aem logo and put a couple to reattach teh two pieces together
Old Apr 21, 2010 | 04:46 PM
  #51
notbrant's Avatar
I wonder if this will affect CA smog law tho?
Old Apr 21, 2010 | 04:55 PM
  #52
Rajca's Avatar
nope
Old Apr 21, 2010 | 05:00 PM
  #53
fsttyms1's Avatar
You should have returned it and got the correct one from the beginning. Looks like You got the one for the TL-P, not the TL-S
Old Apr 21, 2010 | 05:26 PM
  #54
notbrant's Avatar
Yeah, it was my bad, but I got it used on eBAY for 120 bucks, so I guess beggars can't be choosers. Teaches me for ebaying at like 1am
Ill just cut it and use a coupler. If smog station throws a fit ill put stock back on.
Old Apr 21, 2010 | 05:40 PM
  #55
DC3328's Avatar
Your Garage
the piping is smaller in diameter than the type s one. Sell it on the black market for the same price then use that money to buy the correct one
Old Apr 21, 2010 | 11:54 PM
  #56
notbrant's Avatar
If the piping is smaller how does it fit perfectly?
I believe its the same size but they include a 2.5 clamp incase you use it on the Accord V6, but unless im mistaken, piping is 2.75" on TL P and S
Or is TL-S 3"?
Old Apr 22, 2010 | 12:00 AM
  #57
notbrant's Avatar
I guess since im probably wrong ill have to wait a month before I sell on Black Market
Old May 13, 2010 | 09:49 PM
  #58
mrbustrbrown's Avatar
i have a aem v2 on my 2000 with a specter stainless steel filter that is no restriction never needs cleaning and my motor doesnt shake or nada sounds fuckin awesome
Old May 14, 2010 | 08:11 AM
  #59
fsttyms1's Avatar
No such thing as never needs cleaning. If you believe that
Old May 14, 2010 | 11:13 AM
  #60
Rockstar21's Avatar
The Dumb One
im suprised you read that and were able to respond
Old May 14, 2010 | 06:29 PM
  #61
its a stainless steel filter no cotton or mesh or nothing....nothing to clean
Old May 14, 2010 | 06:33 PM
  #62
Rajca's Avatar
so it doesnt filter. so its not an air filter. basically ur sucking up dirt and shit into ur engine
Old May 15, 2010 | 11:46 PM
  #63
go to autozone its a spectre stainless steel air filter go look and see some people r hard headed more than others cn is believing
Old May 16, 2010 | 08:48 AM
  #64
Rajca's Avatar
if its gonna filter anything, its gonna need to be cleaned. end of story. if it doenst need cleaning, its not filtering
Old May 16, 2010 | 02:45 PM
  #65
weirdxpsycho's Avatar
well said.
Old May 16, 2010 | 08:17 PM
  #66
02type-s's Avatar
-Arsenic-
My sister has one on her Focus. Its a stainless steel mesh, but there is a filter behind it. Otherwise it wouldnt be an air filter at all. So yes, of course you have to clean/replace it...
Old May 24, 2010 | 07:28 PM
  #67
Conman16's Avatar
'99 TL
hey guys,new here. how would i add a CAI to my 99 tl? any suggestions appreciated. thanks
Old May 24, 2010 | 07:30 PM
  #68
Rajca's Avatar
by following the diys
Old May 24, 2010 | 09:07 PM
  #69
Conman16's Avatar
'99 TL
links?
Old May 24, 2010 | 09:20 PM
  #70
Rajca's Avatar
everything u need plus some
https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
Old May 24, 2010 | 09:22 PM
  #71
Conman16's Avatar
'99 TL
thanks alot rajca
Old May 25, 2010 | 02:43 PM
  #72
blurrpleberry's Avatar
/Users/mfeely555/Downloads/IMG00008-20100422-1307-2.jpg
Old Jun 6, 2010 | 01:21 AM
  #73
Tosh1's Avatar
Originally Posted by jdjohn84
I wouldn't say there is a 'maze of tubes' in a stock setup, unless you are referring to the intake resonator. Once that is removed, it is a very straight shot.
Amsoil sells filters for air-induction intake systems, and they don't use oil wetted gauze. http://www.amsoil.com/storefront/eaau.aspx
Sorry a bit late on this..but the Injen intake comes with an Amsoil filter that you link.
I just put my Injen intake in this weekend and you can distinctly tell that there is more low/mid end power just by putting that simple add on. I dont even have headers and it feels so much better throttle response wise.
People will argue about filters and dirty filters etc...but in the end these filters are dyno proven for the most part (no ebay fakes).
Old Jun 6, 2010 | 09:17 PM
  #74
assclown's Avatar
2000 acura tl FPR
you're right, i remember seeing the amsoil logo when i was installing mine.
Old Jun 7, 2010 | 10:05 AM
  #75
jdjohn84's Avatar
2003 TL-S w/Navi NBP
I went the cheap route and just took off my intake resonator and installed an Amsoil box filter. Just from that I also noticed more throttle response. If you haven't done so already, I recommend installing NGK Iridium plugs and doing the SeaFoam treatment. Both will increase throttle response even more!
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
datadr
Sep 12, 2015 09:12 PM
Rcelestino93
Sep 11, 2015 12:15 PM
EvilVirus
Aug 31, 2015 05:24 PM
