Installing HID Fog Lights Without Removing Bumper
Old Nov 1, 2008 | 06:19 PM
03tlCHARCOL's Avatar
WIP-Work in Progress
I'm getting ready to install my HID Fog Light Kit. I've read some people have removed the bumper some have not. I've mainly looking at CJITTY's post for guidance. However, does anyone have advice about installing it without taking off the bumper? Can you provide some steps? What's the best place to install it? Can I gain the same access without removing the bumper. I'm not good at putting things back together, so I don't want to attempt to remove the bumper.
Old Nov 1, 2008 | 07:53 PM
Rajca's Avatar
wham bam thank you ma'am
if i were u, id take the bumper off, a couple clips and a couple screws and your set. installing the ballast would be easier too with the bumper off.
Old Nov 1, 2008 | 09:00 PM
AMGala's Avatar
Lamborghini Aventador FTW
^I agree...you need to find a good location to mount the ballast, and it's much easier with the bumper off.
Old Nov 1, 2008 | 10:22 PM
nayaab88's Avatar
wayyyyyyyyyy easier with the bumper off... just man up and do it... i was scared at first too but its not as bad as it seems. just take it off do it right and enjoy the LIGHT!!!
Old Nov 2, 2008 | 01:25 AM
SLAKERZ's Avatar
CITIUS::INFERIUS::FORTIUS
I agree. Taking off the bumper is a good learning experience and may help you in the future. It believe it is possible to do it without though. My guess is to 1.) remove the foglight housings. 2.) reach your hand UP the opening and towards the center of the car and you'll feel a portion of the car's metal frame that is flat. 3.) use doublestick 3m exterior tape to mount the ballast to that flat area... practice mounting it before putting the tape on. 4.) since you won't be able to see it, because the hand and ballast will be in the way, you'll just have to play it by feel. That's how I'd go about it.
Old Nov 2, 2008 | 01:47 AM
TequiLa's Avatar
(ಠДಠ)
try to set the wires so that the wires dont rest on the bottom lining because when you wash your car or drive in the rain, the fogs may not turn on.
Old Nov 2, 2008 | 09:13 PM
CJITTY's Avatar
Ackniculous One
bumper off is easy as hell, well, I made it harder than I had to on my DIY, but trust me, that is the safest location for the ballasts and that weld spot i show in my DIY is the perfect place to keep the ballast secure, stable, clean, minimize moisture and minimize vibrations, especially with the thick 3M tape bonded hella tight to the clean metal surface. Some of the new HID kits out there have very small ballasts with long wires, so eventually you can stick those ballasts in the engine area and drop the wires down to the foggies
Old Nov 3, 2008 | 04:08 PM
Okay I'm going to attempt to remove the bumper tonight and install the HID. I got the slim ballasts man are they small compared to the stock ones. Any other pointers?
Old Nov 3, 2008 | 11:52 PM
Okay guys ran into an issue!!! The driver side foglight will not light up. I tested that both ballast work on the passenger side, however once plug into the driver side it won't come on. I plugged in a reguluar halogen bulb (driver side) and it comes on without a problem any help!!!! I'm stuck!!!1
Old Nov 4, 2008 | 02:34 AM
I finally got it fixed, I had to add an extra wire to make the driver side work. It looks like the stock wiring was not strong enough to handle the voltage. But now after putting on my bumper I feel like theres a gap b/t the headlight and bumper and ideas?
Old Nov 4, 2008 | 04:38 AM
Rajca's Avatar
the bumper goes into tabs under the headlight, u shouldnt force the bumper on, just slide it in, check to make sure that the bumpers edge is between the tabs and not under them
Old Nov 4, 2008 | 11:21 AM
Okay, I guess I'll have to remove my bumper again argh! So just an update guys and rundown.
The bumper removal process wasn't really that bad. It was just figuring out which clips and screws to take out. The thing that fustrated me the most was how the driver side would not work even though I tested both ballasts and bulbs and they worked fine on the passenger side. Luckily the kit came with this additional wire, I tested the wire to the battery and the kit came on. So I than hooked the wire to the kit and there was light! I then zip tied everything and used the same tape CJITTY got from the hardware store, that tape is no joke. Then I placed the bumper back on, but now there is this gap. It was getting late, so I'll probably take off the bumper today and try to refit it again. I'm also going to have to readjust the fogs, how far out should the cutoff be? Thanks for everyone's input.
Old Nov 6, 2008 | 07:48 PM
CJITTY's Avatar
Ackniculous One
yeah, bumper is picky..remount it
Old Nov 6, 2008 | 07:59 PM
FirePR2002's Avatar
bringin lead
^^Jitty's DIY is very good and is the guide i'll use when i do mine. they look excellent in person too.
like you found out, bumper removal isn't that bad. did you take out the intake resonator box while you had it off? if not - kill 2 birds while you're there.
space_boy
ILX
51
Aug 15, 2017 12:06 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
