Installed My Koni Yellows & Tein STech
Today i installed Both my Koni Yellows along with Tein STech Springs.
1st Thing i noticed that My Car suppose to go down 2.1F and 1.6R But it DIDNT!
I didnt adjust the Koni Yellows and put them as they came because i want to see how the ride is like that and than i will decide to Change the settings.
When i took my car for a ride, i saw a significant difference. Did Alot of twists and turns and the Handling is way more responsive than it was before. There was NO body roll which is Good.
Now, From all those twisties and turns and i did, i felt my tires are holding what my konis wants to do. Meaning, those slim and cheap tires (STOCK) doesnt let my Konis do what they want.
Question:
1) Why didnt my car get lowered, is it because they are new and will settle soon?
I Soo Wanted to Post pictures but since my Car didnt Drop, i didnt feel like posting any pictures
Question:
Originally Posted by Phrosttz0
you def still have a good amount of body roll
slobalt defender
set the koni's on the lower perch...that will drop you.
The part the spring sits on.
Originally Posted by lostkhan
What do you mean by Lower Perch??
Originally Posted by formula1
I have the koni sport also w/tanabe nf210 springs.Make shure you get rear camber kits if you drop it on the lower perch.I learned the hard way did not have camber kits, ruined my rear tires after 50 miles.I think your springs also will settle a bit after a while.Get sway bars and you really will feel a difference.
Should i get Both Rear and Front Camber Kits?
slobalt defender
when i had my H&R sport drop on stock shocks i was dropped the normal 1.75/1.5, when i had my koni's put on a year later (on the lower perch) on my h&r's, i got dropped another inch or so. I have 1/2 to no finger gap all around.
3rd Day on KONI YELLOWS:
Ok today i tries FULL STIFF, The car is bouncy on every up and downs on the road. I Feel like throwing now lol. But there wasnt a Significant Change in the Handling than what i had before which was the Original Setting which KONIS came with Just the car is more jumpy. So Than i tries FULL STIFF in the Back and 2 Turns To the Soft Side FRONTS, There are still more jumps in the back i feel and the car is just not that stable.
So the Final settings i got to were 2 TURNS FRONT and TWO TURN REAR (from Firm to soft). This is the best settings i found on the local roads of NewYork.
ill be Posting More Review after when ill put the Konis on Lower Perch!
2009 g37s 6mt
hey I have the same set up and am expieriencing hard road abosption in the front. I have the front and back set to full soft setting. Should I make the front stiff, because that is where the problem mostly is.
BoricuaTL
04-08-2016 01:08 PM
