Hypothetical S/C question..
2001 TL. Eventually I'd like to do the CL-S 6 swap both engine and trans and add a s/c and be done. A used supercharger seems easier to find and cheaper than what I need for the swap. So my question is this: if I were to find a cheap s/c before I have a s type motor in which would be easier: getting the correct one for the TL-P then make the changes to make it fit type S motor or vice versa. I know that it needs some sort of mods to go either way just wondering which conversion is easier.
Find one for the SC and make it work on yours.
remember, the elbow is a cast piece. Not very easy to modify. And in all honesty, the CT mp62 blower is WAY too small for the J32. If possible, get the ct kit and modify a Mp90 blower to it. You will get more power with less boost and less intake temps.
https://acurazine.com/forums/2g-cl-2001-2003-50/mp90-supercharger-retrofitted-mp62-comptech-kit-694376/
Boosted...
2001 TL. Eventually I'd like to do the anodizing swap both engine and trans and add a s/c and be done. A used supercharger seems easier to find and cheaper than what I need for the swap. So my question is this: if I were to find a cheap s/c before I have a s type motor in which would be easier: getting the correct one for the TL-P then make the changes to make it fit type S motor or vice versa. I know that it needs some sort of mods to go either way just wondering which conversion is easier.
The only real difference between the TL-P and CL-S6 supercharger kits is the elbow into the intake. The TL-S has other pieces for the VSA on the intake side, befroe the blower. But the TL-P and CL-S6 don't have VSA.
Chapter Leader (Southeast Region)
This is actually what i'm doing. I have the comptech kit now with HBP on my TL-P, and have my type S motor torn down on a stand in the garage. I really think i'm going to do the new 3.7 internals and then upgrade the blower to the MP90 unit. For the ecu i would like to swap the ecu to the 07-08 type s as well allowing for Hondata or swapping mine to a six speed and running the AEM unit.
6spd ftw. I can't beleive with the difference in price it's just an elbow. If I remember correctly the one for the 6spd was around 4000 and the one for the type s auto was around 4500
I remember reading somewhere that you can't run boost or nitrous with the 3.7 build. You might want to look into that before you do that.
If you kept the stock 89mm bore and left it at a 3.6 you could, or you would have to resleeve it with something stronger. While im sure you could get away with low boost like3, im not sure i would run 6 or higher
Yeah I remember reading a post by nva-av6 that said the motor is built for n/a and shouldn't be used with any type of forced induction. I think it was something to do with the cylinder walls which you seem to confirm. I think that would be cool to see a supercharger on a 3.7
