How to Remove Resonator !
Okay Fellows I would like to know how to remove the resonator step by step.
Pictures if possible . I have Searched but , they were all incomplete or had no pictures to help me.
I would like to remove all resonators , or just the ones that would give me more loud when i floor it.
Thanks for all the help
Maybe itanke resonator + exhaust's both resonators if possible with pictures please
I have a 99 tl thanks much
I have taken out the intake resonator..... pretty simple. As fas as the Exhaust resonator, don't quote me on this, but I think you have to cut it off of your exhaust pipes and then weld on a straight pipe. If that's something that your capable of doing, then it shouldn't be to hard.
Now, back to the intake resonator: First off, I don't have any pics. I removed mine when I was changing my brakes.I would remove the drivers side front wheel first, then you have to remove the plastic that is under the from bumper (not sure what that's called by the way, but it covers the bottom where the resonator is at.) Now to remove that plastic you have to undo some fasteners, which are a pain in the ass. If I remember correctly you have to turn the center part and then press up on the surrounding part, which will unlock it. Now, this is pretty tough, but don't let it discourage you from reoving that resonator. Oh yeah I think you will have to remove some of those fasteners in the wheel well too..... just for a little more room to work.
Once that plastic is removed or just hanging off enough so it's not in the way, you have to unbolt the resonator which consists of 2 bolts. I know that sounds easy..... but only one is. If you are under the car you will see the resonator, it's huge, you can't miss it. There will be one obvious bolt and the other is kinda behind the headlight. You wil have to remove that one and then just yank the bitch out.
Sorry, it's kinda fast, but I'm at work. Hope you can figure it out.
heres the DIY....have fun..--> http://www.abunchofcars.com/diy_page.../resonator.htm
dainmezron
Oct 16, 2015 06:56 PM
