High flow cat w header worth it??
Old Dec 12, 2011 | 09:37 AM
Oakroadsteve's Avatar
I have the typical mods and headers and am considering a RT High Flow Cat. I have done the searches and read a host of posts but I have not seen any definitive first hand experiences concerning acceleration/performance increases.
I understand that there may be a torque loss and that any gains realized are at the top end. My question is will a high flow cat cut my 0-60 or Qmile time by a tenth? The RT's go for a couple hundred and then there is the labor. If I don't around 10hp then it is not worth the $$
Sure would appreciate some first hand experiences with this....
Old Dec 12, 2011 | 02:11 PM
Karanx7's Avatar
Unregistered Member
There's no way you'll cut a tenth.
I seriously doubt you'll get 10 hp out of it. 5 at the MOST.
Also, it won't be worth the rasp you will get.
Even if you just got a test pipe, I don't think you would get 10hp.
Old Dec 12, 2011 | 03:09 PM
Thanks K7.....From what I have read a test pipe ruins the exhaust tone.
I believe you gain a tenth in the qtr for every 10 hp you add. As the gains with a high flow are in the upper end of the rev range that would most likely not be case here.
Old Dec 12, 2011 | 05:39 PM
yeedatoy's Avatar
kill you till you die
I looked into this too and could not find any dyno #s for the j32. The newer accord guys and The TSX dynos claim/show gains only at the very top of the RPM band and a loss in power through the rest. For the money I don't see it being worth it unless you run boost and race your car. You will make better gains with a cold air intake for much cheaper...why not pick one up if you're looking for more power, plus you can do the install easily. Furthermore, I think a $400 racing cat should have some dyno #'s available to the consumers.
Old Jan 3, 2012 | 12:06 PM
Toms02TL's Avatar
i got the manaflow high flow cat and to be honest im pretty sure it didnt do a god dam thing lol
Old Jan 17, 2012 | 04:18 PM
BlueIce0002's Avatar
3rd Gear
I have DC Sports headers and an excelerate high flow cat. Headers gave a huge gain and the cat didn't do shit except now my exhaust sounds raspy
Old Feb 26, 2012 | 06:32 PM
NAPZTYPES's Avatar
i have a random tech high flow cat and dc sport headers and an atlp exhaust ....and yes it did make difference
Old Mar 2, 2012 | 01:19 AM
MilwaukeeDave's Avatar
So a high flow cat can cause you to lose torque?? Is this also true about headers? I'd like a new exhaust mostly for sound reasons but some HP wouldn't be bad either. But if I'd lose torque I'd rather not.
Old Mar 9, 2012 | 04:37 PM
kuckle1's Avatar
Is switching the piping on a stock exhaust system a difference in anything at all? Just a question
Jul 16, 2017 07:33 AM
DerrickW
Nov 15, 2015 05:52 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
rockyboy
Sep 29, 2015 12:05 AM
