HID light questions...
Old Aug 23, 2008 | 10:18 AM
Slepybear's Avatar
fu
Alright, i currently have the OEM headlights, and some pretty basic h11 foglights, which are not HID.
I want to upgrade both to HID and I have some questions.
1. I want 8000k, will that cause any problems?
2. Will matching them look stupid? or should i mix them for a different range of light?
3. WHat do i need? do i need a new balast for each light?
4. Is instalation pretty much just plug in and use? or does it require fitting it?
5. what size is the TL's bulb?
Old Aug 23, 2008 | 11:18 AM
Rajca's Avatar
wham bam thank you ma'am
u need a whole new or used hid kit for your fogs, i believe that the bulb is an 9006. 4300k is stock, 8000k would be blue, the higher in K u go the more blue its going to output. i have 6500k in my headlights and it gives out some blue but i see better in night with the 6500 then the 4300
Old Aug 23, 2008 | 12:59 PM
Slepybear's Avatar
fu
alright..
also, how can i tell if the lights burned out, or something else happened?
everything worked before, and now the fogs won't turn on.
the button lights up, so i think power is going to it, but both lights went out at the same time in not a lot of time.. a couple months
Old Aug 23, 2008 | 01:03 PM
Rajca's Avatar
u have the accord fogs in your car, right? maybe u had a short in the wires, i had both of my fogs go out one day and i just put two new ones in and and it still works, dont know what happened but it did and hasnt happened again
Old Aug 23, 2008 | 01:27 PM
Slepybear's Avatar
fu
civic fogs, but so replacing the bulbs should fix it?
Old Aug 23, 2008 | 01:34 PM
Rajca's Avatar
check your wires for any shorts, since its a custom job, then replace them and see what happens. but if everything is straight with your wires than replace them and see what happens.
Old Aug 23, 2008 | 02:34 PM
Slepybear's Avatar
fu
ugh, alright,, sounds like an all day job.. just thought of this, we just plugged the wires into the fuse box right under the steering column, could it be blown?
Old Aug 23, 2008 | 02:40 PM
Rajca's Avatar
thats a possibility. did u look at teh bulbs too see if they were blown or not?
Old Aug 27, 2008 | 11:34 PM
Slepybear's Avatar
fu
Alright, just so i (think) have everything right.
I plan to buy an HID kit, which means i need new ballasts and everything?, and the bulb size needs to be 9006, and I plan on going with a output of around 7000-8000k, which may look a little blue, but I am ok with that.
For the fog light i will check for shorts as soon as I can, but afterwards I will need another set of ballasts and lights to get HID in there as well??
Sorry if I am coming off as dumb, but I can't afford to be throwing my money into the wrong parts, and I really want to get this right the first time
Old Aug 28, 2008 | 05:03 AM
Rajca's Avatar
your stock headlights already have hid for the driving lights, all u need is a bulb and for that contact excelarate (d2s i think the bulb is),
since u have the civic fogs u need a h11 bulbs and teh kits, (bulbs, ignitor, ballast)
Old Sep 1, 2008 | 12:12 PM
Slepybear's Avatar
fu
alright, thanks
Old Sep 11, 2008 | 10:20 PM
Shocker0316's Avatar
Everything you need is at this website..i have a 99 tl and i just bought the 8000k lights...they are awesome. plus they have the kits for every type of headlight avaible!!
http://www.wholesalehid.com/
Old Sep 12, 2008 | 06:55 PM
ftLauTL's Avatar
Ya....It's an Acura
hmm
Beside the 01-03 civic fogs, what other fogs will fit my 00 tl-p?
Old Sep 12, 2008 | 09:25 PM
maniaC_99's Avatar
...advance...
6g accord fogs are perfect!!
definitely a mod ill be doing in the future.
here is a link to subtledreamer's diy : https://acurazine.com/forums/2g-tl-1999-2003-98/replica-6g-accord-4dr-foglights-diy-612321/
its also on the diy stick if you look for it.
Old Dec 31, 2009 | 06:07 AM
PSUALLDAY's Avatar
I have a 03 tl and I'm trying to change my stock fogs into HID's. What size do I get? h1, h3, or 9006?
Old Dec 31, 2009 | 07:30 AM
rockstar143's Avatar
ddmtuning(dot)com.
$29 bucks for the whole HID kit with lifetime warranty can't be beat.
I changed my lowbeams to 6K and installed the bumper fogs and HID's to match.
Can't go wrong for that price.
put them in my gf's car too...
Old Dec 31, 2009 | 07:56 PM
`ill*tl's Avatar
Originally Posted by psuallday
i have a 03 tl and i'm trying to change my stock fogs into hid's. What size do i get? H1, h3, or 9006?
9006
BoricuaTL
Apr 8, 2016 01:08 PM
pozebly
Sep 23, 2015 07:30 AM
JnC
Sep 11, 2015 06:06 AM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
voigt
Sep 2, 2015 10:44 PM
