headlights
-Arsenic-
Someone correct me if I'm wrong, but nobody makes aftermarket headlights for our cars, unless you just want factory ones. Most people take them apart and either paint the housings of retrofit some projectors.
Former Sponsor
If you are looking for replacement headlights i.e. exact same as the OEM ones then Depo makes them but if you are looking for projector etc then no there are non for the 02-03 TL.
Former Sponsor
Your car comes with the most potent 35 Watt HID bulb. HID bulbs are known to loose their output over there life time but it isnt that noticeable. If you want you can always replace your current bulbs with 4300 Phillips D2R bulbs. I wouldnt recommend going with BLUER bulbs such as 6000K etc, when you go with higher Kelvin bulbs you loose light output. Here is a good rule of thumb, spend money to get light that is usable to you rather than for show off purposes.
Former Sponsor
^^ If you want bright and more road illumination then do a projector retrofit. Even though out cars have HID in them but the reflector setup does not utilize the full potential of a D2S hid bulb. I will have comparison shots available in my retrofit thread in a few weeks comparing a standard 00TL headlight out put with one that has projectors retrofitted in it.
ok...how much does it cost to do that and what about the high beam bulbs and fogs...ive heard of someone putting HIDs on the fogs but would that be as bright as just putting a better bulb cost wise and i have a optima yellow top in my mustang that i plan on putting in the TL and that battery brighten the mustang lights would it do the same for the TL or does the TL get the power already that it needs
JOSH
JOSH
Former Sponsor
JOSH
JOSH
Former Sponsor
well i actually live out in the country so i use my high beams a pretty good bit because of the deer out here
JOSH
JOSH
Or do a Bi-xenon projector retrofit. You will love the high beams in the projectors, they will light up trillions times better than your current high beam (you can still keep your current high beams). Knowing the size of the TL headlight your options are E55 (maxima), FX46/G35 bixenons.
AmplifiedDetails
09-24-2015 02:55 PM
