Flame Thrower :flamewar:
I wonder if our cars run rich enough, along with my straight pipe and high octane gas to make a flame, with a spark plug powered by a coil welded into the tail pipe without any additional fuel injection?? My grandpa fills my head with tails of blue flames emitting from muscle car tail pipes at night as cruise through the night time hwys of el paso. My exhaust stinks of unburned strong exhaust and I would like to do my part for the environment by not letting unburned emmitions seep into the atmosphere, so anyone speculate, if this can be done without adjusting the timming, or any other modification other than sticking a coil powered spark plug 3 to 6 inched from the exhaust tip???
anyone done it?
Even if there was enough raw fuel in your exhaust (which i dont think there would be) the flame would be very small, you would need to add a fuel source to make them bigger.
Hello Officer
Its different on hotrodders (which actually have far more power than imports). Its hard to explain, just the point is there is a difference on the mods you can do to both muscle and tuner cars..
FlacoJ, If you want to get rid of tailgaters I would suggest installing HID Reverse lights with a switch (a fellow 3g Member has accomplished this). That'll be good enuff. Although be smart when using these.
![](http://mysite.verizon.net/jaybird27/IMG_1423.JPG)
Thread: https://acurazine.com/forums/3g-tl-2004-2008-93/led-reverse-lights-752576/
B A N N E D
anyone done it?
and if he wanted to shoot the flame further, he should go down to one muffler instaed of duals (for higher velocity out the tip)
and i still would think it is
![Rice](https://acurazine.com/forums/images/smilies/rice.gif)
thats what i was afraid of, even though i have a single exhaust pipe, no cat, and headers, I researching how I could possible get that much uncombusted fuel, and in theory, maybe it would work if I engine braked down from vtec in 2nd gear or so. In my old straight pipe steup i had a rasp when i held it in 2nd and let the car wind down from a high rpm, as seen here http://www.youtube.com/watch?v=-6elEBaobrw, and i want The Active Ignition method of producing an exhaust flamethrower involves installing and wiring the kit properly and the igniting the unburnt fuel. This kit works best on vehicles without a catalytic converter or with an older converter. Vehicles with large motors, power modifications etc. will produce good flames... often even with a catalytic converter. Using higher octane fuel can also make an impact on the size of the flame - as will altering the fuel mixture so that you are running rich. This kit will cause less wear and tear on the motor/exhaust
I don’t want to add any extra accelerants, i don't care if the flame is huge, I just want to be the only TL in my neck of the woods with this mod, if I can do it without taking off the fuel pressure regulator, or mixing race fuel
B A N N E D
but yeah that will make the exhaust extremely rich too by cutting the spark, when you hit the rev limiter, or let off the throttle for decel mode
B A N N E D
but for the rev limiter it would be better for it just not to fire instead of it going completely lean and destroying the engine
this is how the op's car will end up, http://break.com/index/pimped-out-ca....html?matchid=
/thread.
/thread.
