exhaust piping
Old Mar 21, 2009 | 12:26 AM
III.II's Avatar
exhaust piping
What's the diameter of the stock axleback piping for the 02 TL-P ? I want to weld on mufflers just making sure the inlet is the correct size. Thanks.
Old Mar 21, 2009 | 12:28 AM
jjashaa's Avatar
Avant Garde Wheels
you're in cali?
hold on, let me go measure mine
Old Mar 21, 2009 | 12:32 AM
jjashaa's Avatar
Avant Garde Wheels
about 1.5 OD and 1.47 inner diameter..
Old Mar 21, 2009 | 12:50 AM
III.II's Avatar
Should the inlet of the muffler be 2.25" or 2.5" for the TL-P's?
Old Mar 21, 2009 | 12:53 AM
zeppler's Avatar
its a personal choice really
your gna have to get some small piping from muffler inlet to your pipes
one size to match the pipes, the other tip stretched out to fit over your muffler inlet
Old Mar 21, 2009 | 01:17 AM
III.II's Avatar
what would you do ? which is better? 2.25 or 2.5?
Old Mar 21, 2009 | 02:36 AM
jjashaa's Avatar
Avant Garde Wheels
jus get 2.25
zeppler's Avatar
go with 2.25 since ur stock piping is already pretty small. it would give you a better flow.
what type of mufflers are you going to put on?
Old Mar 21, 2009 | 03:55 AM
III.II's Avatar
Magna Flow 14829
Old Mar 21, 2009 | 04:22 AM
zeppler's Avatar
mmmmm very nice
go with the 2.25
Old Mar 21, 2009 | 04:42 AM
III.II's Avatar
I'll do that. Thanks for your guy's help.
Old Mar 21, 2009 | 05:23 AM
zeppler's Avatar
if your doing this urself. post pics up of the process
maybe a video after? i have flowmasters, and i like em a lot. wonder how magnas would sound on a tl
Old Mar 21, 2009 | 10:45 AM
fsttyms1's Avatar
Exhaust Diameter is 2" for the TL-P. 2.25 for the TL-S. After the Y it does seem to narrow down though.
Old Apr 20, 2009 | 12:48 AM
slvrcrunch's Avatar
i want to get flowmasters but dont know whch ones. which ones would you recommend
Old Apr 26, 2009 | 04:49 AM
zeppler's Avatar
i had about 5 different sets of exhaust with diff size piping. i think i finally found a setup i like
flowmasters, ud probably wnt to stick with the classic 40s delta flows, they are designed for newer cars and are probably the only ones that you can find that will fit a tl perfectly.
flowmasters are metalic. i mean straigh metal. thick heavy metal.
therefore the sound will be metalicish(??)..
i had a setup of cat, factory piping, mid muffler delete, and 2 flowmasters. it sounded good. pretty loud. but there was A LOT of in car resonance and vibration.
if you have subs, forget enjoying them, ever. if ppl are going to talk in ur car, they better be right next to your face.
just today i got a new setup, (because of a little stupid accident of backing into a curb, and bending my piping)
from header down, i have a 2.5 inch piping, with a 24 inch resonator pipe in the middle, back to 2.5 piping, no mid muffler, into a magnaflow muffler. it sounds great, and its smooth and comforatble inside. no vibration, or EXCESSIVE sound. i can listen to my subs again. oh btw. i have no cat. and its single exhaust now instead of dual.
i gained more power, with single and no cat.
dont go over 2.5 piping. u'll loose power
but if you are serious, id recommend you saving a bit and going with magnaflows. better perfomance, better sound. and its all chrome and shiny instead of a dull metal chunk.
DerrickW
Nov 15, 2015 05:52 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
johnpancakes014
Sep 27, 2015 12:58 PM
Rcelestino93
Sep 23, 2015 10:01 PM
