Dynoed & Depressed
Its more like a whiny noise.. it dosen't sound normal... one thing i noticed is a sensor on the driver's side near the strut bar is making a loud ticking noise.... i'm gonna post a pic but i know that noise isn't normal...
How did you "check" them?? Did you remove the upper intake manifold and look, Did you flip it over?
That ticking IS normal for us. Its the Purge Control Solenoid. They do become noisy.
I sprayed around the gaskets with some brake cleaner to see if the idle would change.. should i remove it? also should i get a new gasket when i take it off(I have the thermoblock spacers) Also i'm gonna remove the IVAC how would i know if its bad?(dealer price around $170) Dosen't running lean point to a vaccum leak?
Ive told you 3 times now to take the manifold off and flip the gasket over. There have been a few that have installed the gasket upside down and it has caused issues with CEL. Only way to know is if you take it apart and flip it. You cant test it by spraying something around it.
I think Kris means the metal OE gasket that is the base gasket, gets flipped upside down under the thermoblock during install, and has caused at least 3 other members a similar problem
You need to spend 30 minutes and pull it all apart and reassemble.
While its off- the TB can be turned upside down and the IAC cover and valve easily accessed and cleaned with carb spray cleaner
Lean plug can mean many things-
the coil test is not simply unplugging one- it requires taking 1 known good one (good to have TL friends) and try it cylinder by cylinder to see if it makes it better somewhere.
1 coil make be partially working- weakly, and your test wont reveal that.
Whenever stumped by a problem- take off whatever you did, and start from scratch putting it together again. That usually fixes it.
did you check the large edge gasket under the top of the manifold cover- another member with thread on -Miss and CEL- finally rechecked that gasket and it was indeed upside down and once installer to spec the car runs perfect
D-Rob
62
Jan 5, 2016 11:44 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
