dropped tl
Old Jul 12, 2012 | 03:13 PM
kambo_inspire's Avatar
dropped tl
So i want to lower my 2g tl and idk how i should go?? I want the fenders right over the stock 17" rims but i dont want to much camber. Any advice on the drop,ive already seen a Tien S kit that'll lower 1.6/front and 2.4/rear..is this wat i should get??
Old Aug 1, 2012 | 09:56 PM
01tl4tl's Avatar
I had to raise the rear on my 01, 1/2 inch from tein setting to get fender clearance in the back with 235s, 225 fit no sweat
some fender mod took care of it
camber beyond neg 1.5 is bad on tires
then its time for a camber kit install
Old Aug 1, 2012 | 10:30 PM
Italiano's Avatar
Keepin your Toe adjustment in check is most important...camber kits will help dial in the 0 toe setting as well that's desired....I agree excessive camber over 3 degrees could be a problem...but up to 3degrees can work with FULL TOE ADJUSTMENTS....Point being..don't be scared of alittle camber.....
Usmcgrunt47
Oct 13, 2023 09:35 PM
emailnatec
29
Sep 28, 2018 04:27 PM
bluetl04
Aug 16, 2016 02:49 PM
us285126
Oct 2, 2015 02:03 PM
4drviper
Sep 23, 2015 07:42 PM
