To do mods
Old Feb 21, 2011 | 03:38 PM
2ndgentl's Avatar
To do mods
I have an 03 CL-S 6-speed I/H/E im about to do my timing belt/water pump. Since im going to spend a few hours on my car I was thinking about getting an Underdrive pulley/P2R intake manifold gasket/P2R throttle body gasket/and a 60 degree celsius stat (140 farenheit). Would all those mods be worth it or only some?
Old Feb 21, 2011 | 06:04 PM
01tl4tl's Avatar
your in gen2 TL but engine is the same
all those will make the car faster- the light pulley allows rpm to build quikly to vtec where the power is
Spacers prevent massive heat transfer to the intake manifold,, cooler temp there is good
no need for lower thermostat- the engine is very happy 1-2 clicks below half at all times
and needs enough temp for everything to operate as designed
compare bomz pulley (cl group on them for years now) and Outlaw Engineering spacers
the spacers are different technology material and method--you decide whats best for you
make sure to get the maker suggested belt for whichever pulley you choose
the edges are different than OE and the right belt wont make noise
Excelerate has UR pulley in regular and underdrive versions- both lightweight
01tl4tl's Avatar
dont forget to clean the intake manifold EGR system all the way thru
Old Feb 21, 2011 | 07:46 PM
KskSpeed's Avatar
Former Sponsor
We have the P2R Thermal Gaskets in stock.
P2R Thermal Intake Manifold Gasket
$33.20
P2R Thermal Throttle Body Gasket
$21.85
www.KskSpeed.com
Old Feb 22, 2011 | 11:33 AM
2nd Gen 02 Type S's Avatar
how hard is it to change to light weight pullys and where is a good place to order them
Old Feb 22, 2011 | 11:37 AM
jjashaa's Avatar
Avant Garde Wheels
any of our vendors!
I supported my local vendor HeelToe for most of the parts I wanted for the TL.
Old Feb 22, 2011 | 11:39 AM
01tl4tl's Avatar
you remove the pulley as part of the 105 service- just 1 big bolt at 173 foot pounds torque
install new one in its place with correct belt if underdrive version
ck ebay for bomz brand- send message to them if not listed- they do have ours
and will make a private aucton for you
I thought the P2R stuff was more $$ than UR?
Old Feb 22, 2011 | 11:40 AM
01tl4tl's Avatar
we only change the crankshaft pulley- not the alt or ps--they dont need it
Old Feb 22, 2011 | 07:38 PM
2ndgentl's Avatar
2ndgentl
Do they make just a lightened crank pulley? I heard that underdrive pulleys mess things up, is that true?
Jul 16, 2017 07:33 AM
Oakroadsteve
Oct 28, 2015 10:28 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
lanechanger
Oct 13, 2015 10:56 AM
