DIY Cleaning the CT SC?
i've tried the search and this is the closest i got
https://acurazine.com/forums/showthr...t=SUPERCHARGER
did anyone clean their used SC b4 they put it in?
tearing it down and cleaning ever part. i've finished cleaning just about everything except the blower... don't want to disassemble it without some instructions and if there is any torque specs on anything when i do take apart?
well i guess ct-engineering isnt' trying to help... i got no response from them
looks like the tourque specs is as tight as i can get them hahaha hope i dont' end up fucking this up....
any help would be greatly appreciated.
If you don't end up getting anything on paper, one thing you could do if you have an adjustable torque wrench is to use it to find out what the bolt is currently torqued down to. Just start with a small amount of torque, try to remove the torque, and if it clicks, increase the torque a little, try again, etc. until you can remove the bolt. Then record that torque.
^^ yeah i might just end up doing that.... going to be very time consuming though.. bah
I've been emailing them several times and gotten a response within the day either for some missing parts, a check list and the installation instructions which they kindly helped but now they have been either MIA or just plane out not responding anymore...... i'll send a follow up email. and same with the posting in the CL side.
thanks
Originally Posted by L's TL
Did you call or email them? Post this on the CL side there are alot more guys over there who have had SC experience
thanks
