Corvette power train in a 3g TL
Old Nov 28, 2006 | 09:19 PM
fireblade20772's Avatar
3rd Gear
Hopefully I have your attention. What I have realized is that we all want more power. A 350hp and a 3100 pound chassis would not be bad but currently it is impossible given for on the fragility of the engine and that piece of crap transmission. What I propose is to go a powertrain swap with the 6 liter corvette power train. If one wanted to build a performance engine, it is possible since all the performance aftermarket parts cater to GM systems. I don't have the time or resources currently to do it. But I definately will consider it when my tl's powertrain is at its end but the rest of the car is still tight.
Art
Old Nov 28, 2006 | 09:32 PM
sbuswell's Avatar
I need 2 more gears
it will never fit without extensive chassis and body modifications. unless you are a master auto body mechanic with precision tools the cost would outweigh the gain. you could buy a vette cheaper.
Old Nov 29, 2006 | 06:45 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
i think i might have to second sbuswell on this one. i don't know if it would necessarily stack up higher than the cost of a new corvette, but it wouldn't be very cheap at all. bottom line though is that anything can be done, given you have time and money.
just think of what the first guy thought when he dropped a northstar v8 into a fiero.
SSTS
Old Nov 29, 2006 | 09:41 AM
unlemming's Avatar
Smitty's Moral Police
uh, while the tranny certainly had it's issues the engine is far from fragile. The good news is if you're waiting for the engine to die you'll have a lot of time to save up for a vette engine and the related costs.
Old Nov 29, 2006 | 09:59 AM
fsttyms1's Avatar
Id bet big money it would fit just fine as long as you kept it front wheel drive. but who would want to do that
Old Nov 29, 2006 | 10:01 AM
fsttyms1's Avatar
the motor on the TL is not by any means fragile. It will handle lots of power. Just check out the 3rd gen areas and 2nd gen CL and see. We even have a member shooting for well over 400 with a turbo project.
Old Nov 29, 2006 | 10:17 AM
TLMugen's Avatar
I'd rather be driving:
Remember there's a crapload more to consider than just the drivetrain for this swap to work; you're going to have to re-engineer the whole car. It would probably be a lot easier to weld up a tube chassis and hang all the TL sheetmetal on it (of course it wouldn't be street legal then).
Old Nov 29, 2006 | 11:04 AM
fsttyms1's Avatar
yea if you make it rwd, if you were to keep it fwd not much would have to be done.
Ive seen a GM northstar in a VW golf so i know a V8 would fit in the front of the TL.
Old Nov 29, 2006 | 11:26 AM
TLMugen's Avatar
Yeah, you can wedge a NS V8 into a FWD car if you cut out enough of the unibody and then properly reinforce it. Remember, he wants to use a Corvette driveline. There isn't a transaxle that'll bolt up to that LS1 (or 2 or 7 or whatever).
Old Nov 29, 2006 | 11:32 AM
fsttyms1's Avatar
I bet you wouldnt have to cut any thing out. The engine bay on our cars is huge! Now to make it rwd, thats a different story. There isnt nearly enough room down the middle for a rwd trans and shaft without serious modification
Old Nov 29, 2006 | 12:42 PM
malingator's Avatar
Nitrous TL
One word....why...I'm all for power but why do it in a fwd car? Why not a G35 rwd... then again, with all the turbo kits for a G why do the swap at all...
If only we had a better tranny...rwd....and tuning for turbos......the TL would be near perfect...
Old Nov 29, 2006 | 01:43 PM
mr.motoring's Avatar
checkmate...
Because it's not my TL, my money, or my time, I say go for it!
I always like to see these projects.
Although by using the L37 Northstar and keeping it FWD, it would be alot easier. Almost 300 ponies and 300 pounders!
Old Nov 29, 2006 | 02:09 PM
type-s09's Avatar
13.2@ 107 on Street tires
ill pass
Old Nov 29, 2006 | 02:17 PM
fsttyms1's Avatar
I was actually looking into that instead of the 6speed
Old Nov 29, 2006 | 02:46 PM
checkmate...
Me wishes you would have done it. But then would a manual be able to be bolted up to it too? hmm...
Old Nov 29, 2006 | 02:51 PM
fsttyms1's Avatar
Nope. and thats one of the reasons i went the way i did. I wanted a manual
Old Nov 30, 2006 | 09:32 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
i think that u would have better luck with a 350z or G35 power train.
Old Nov 30, 2006 | 09:52 PM
MikePA's Avatar
Art
Heck, why don't you just drop a 572 Chevy big block with a 4-71 blower on it in the TL engine compartment. Better yet, drop the 572 on a separate frame and just drop the TL body on top if it.
Old Nov 30, 2006 | 11:33 PM
SuperTLfans's Avatar
maybe you should just put a 455 under the hood....
actually me and my friend are starting a project soon...putting LS1 or LS2 to a
SC 400 and twinturbo it.. hope it will start soon ....
Old Dec 1, 2006 | 03:19 PM
paul_huryk's Avatar
Pleasure Unit
If you want to get Corvette power in a 4 door sedan, go out and get a caddy CTS-V with the 400hp LS series motor.
It does weigh more than a TL, but is RWD, has a manual trans, bigger tires, better brakes, and more agressive chassis. You can pump it up to 500hp easy and still get 25mpg on the highway.
Acura604
20
Aug 5, 2017 12:55 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
Thuneau
Oct 3, 2015 04:19 PM
