Coolant Bypass
Coolant Bypass
I remember seeing a detailed post with photos on how to do a collant bypass on the throttle body of a TLS... am not able to locate it in searching the site. Can someone please repost or provide link to it. Thanks much!
MechEng
just to be clear, you mean unplug to two hoses running into the TB and connect them together right?
do you also have to plug up the spots where the hoses were on the TB so dirt doesnt get in?
Does this damage anything at all? any negative side effects? and also anything like this you could possibly do to your tranny? =)..
also i thought since breather was mentioned here i won't create a new thread.
where exactly do you put the breather on? i looked and couldn't figure it out. i feel stupid lol.
no there's no damage to the throttle body. well you could by a transmission cooler but that won't really help with the 3rd clutch pack problem. the breather is to look cool. jk about that part. its so it doesnt re-route back the dirty air from the valve cover back into the engine. you don't have to feel stupid lol its all part of a learning process when you ask others question concerning your car and mods. so feel free to ask questions, that what we're are here for.
just to give in my
, i did this mod maybe 2 weeks ago. ive had 2 tl's in the past 4 years and never did it. at first i didnt realize anything since i didnt drive that long. did a test within the last week with longer, aggresive driving. i did realize that after driving for a while it doesnt hesitate as much. this is worth the 5 mins of work.
2003 TL-S w/Navi NBP
You have to use a by-pass fitting to connect the hoses, usually made of brass. What size is the inner diameter of the hoses, guys? 3/8"? The coolant is routed through the throttle body in order to keep it warm and prevent sticking during cold weather. By doing the coolant by-pass, the throttle body will stay cooler, so the air passing through it will also stay cooler, and burn better in the cylinder. A throttle body spacer, and also intake manifold spacer, also help to keep the intake air cooler.
Has anyone ever had problems with TB sticking in the winter after doing the by-pass?
to be honest, yes it may be improved n all that fun stuffs but its nothing drastic that your going to feel. its just little mods like these that give you a couple hp here and there that add up. and i drove my car thru all the snow we got here last yr (snowplow) and it didn't stick at startup or anything.
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
