Comptech axleback imbalance fix & painted y-pipe
Old Sep 4, 2006 | 04:23 AM
subtledreamer's Avatar
woooo!!
Talking Comptech axleback imbalance fix & painted y-pipe
Zip ties & a little of brainwork is your friend
I had the CT axlebacks installed yesterday but the end result was that my left tip is hanging so high that its smashing against the rear lip and melted some of paint/plastic after a short drive. The right one was actually hanging at a good height... unlike most people here with it sagging a bit.
I spent a good hr and a half under the car trying to figure it out by nudging the rubber hangers and rebolting the muffler back on... no luck. Finally I thought about removing the rear rubber hanger so that the muffler hangs down more. After some uber fancy zip-tie work (pulling it towards the inside (front hanger)), i was able to position it perfectly in the middle of the cutout with a pinky gap below the rear lip I had to adjust the right one to match the left too... by pulling it up (with the rear hanger) and also in-ward a bit (front hanger).
End results: perfecto. It looks impeccably balanced I would recommend this trick to anyone who may be running into a similar problem with the CT's or other mufflers/axleback systems. Just be sure to use (2 or more) thicker/strudier zip ties.
Some pics of the front hangers, I left the ends of the ties so that in case I need to tighten them in the future I still have something to pull on
Also... I've always thought that our stock y-pipe looks horribly ugly from the back especially when driving at night and its dull brownish copper look attempts to shine underneath the car. And especially with aftermarket mufflers only... the y-pipe stands out even more with the stainless tips & cans connected to it. The fix: black high temp paint!
Here goes:
Old Sep 4, 2006 | 06:11 AM
AznWay's Avatar
Old Sep 4, 2006 | 09:17 AM
ryebreadisme's Avatar
Low and Slow
Great fix man. Looks amazing. I've never run into anything like this with the other setup I was running, but that's definitely great advise for the future. Also good fix with the Y-pipe. Looking good as always
Old Sep 4, 2006 | 09:19 AM
fsttyms1's Avatar
Great!
Old Sep 4, 2006 | 09:59 AM
TLsu's Avatar
Wallace, LA
Another excellent write up by subtledreamer....
Old Sep 4, 2006 | 11:26 AM
PiZauL's Avatar
W00t
Ahh, the power of zip ties. Good write up. My problem with my magnaflows is they are facing inward. They are right on level but not directly under the exhaust cutout. I gotta get under and play
Old Sep 4, 2006 | 11:33 AM
Phesto's Avatar
will the zip ties still hold even after the mufflers heat up......I want to try this on my passenger side that hangs low,but I am wondering if metal zip ties or even a hose clamp might work longer?? TIA
Old Sep 4, 2006 | 01:05 PM
woooo!!
Cool
Thanks for all the comps guys
Metal ones most probably would last longer, but I was at home and the only thing I had access to were plastic zip ties The hangers that the zip ties are tied onto are actually a separate weld that comes from the side of the muffler (as you can see from the pics), so I am hoping that insulates most of the heat. Worst case scenario for me, I'll just have to switch to metal clamps/zip ties once these deform or melt completely
Btw, I want to mention that when I said "removed rear hangers," I meant the one towards the front of the car... sorry about any confusion with the naming and angles. When you work on your car upside down everything gets weird
and two more pics of my work with the "rear" hangers:
driver side muffler:
passenger side muffler:
Old Sep 4, 2006 | 09:50 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
i doubt its going to heat up that much i didnt see any zip ties actually touching the exhaust it was all hangers.
Old Sep 4, 2006 | 11:30 PM
MrAlex's Avatar
99 SSM Tl
Zip tie wont last , they will become dry after couple of time and break ..
Old Sep 5, 2006 | 12:49 AM
woooo!!
i'll utilize the same idea with more weather-resistant solutions then
Old Sep 5, 2006 | 10:40 AM
joseph_99tl's Avatar
u can get stainless steel zip ties.
SidhuSaaB
May 30, 2020 12:40 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
k6biv
Sep 22, 2015 02:06 PM
JnC
Sep 11, 2015 06:06 AM
