Changing Stock Speakers
Old Sep 27, 2006 | 07:42 PM
xxnonamexx's Avatar
I have a 03 TL types S I have a JL audio 2 12" speakers box and a JL audio amp 300watts. I do not want to replace the factory unit. Would I be able to replace the stock speakers to give a better sound? If so what is recommended?
Old Sep 27, 2006 | 10:17 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
i recommend searching.
Old Sep 27, 2006 | 11:18 PM
fsttyms1's Avatar
Any thing other than stock. replacing the BLOZ headunit is the best place to start. seeing you dont want to do that. Id look into a good set of component speakers to replace the door speakers. (polk,mb quart) are good
Old Sep 28, 2006 | 06:38 AM
xxnonamexx's Avatar
I have searched and most posts I read are about people adding a system, amp, or changing speakers in the newer models. I have a 03 Type-S I installed tweeters in the window columns so I have 4 tweeters. I do not want to change the head unit. I read that using MB Quart I would need to add another amp which I am not looking to do. I just want to simply replace the existing door speakers for something better. Thanks
Old Sep 28, 2006 | 09:16 AM
fsttyms1's Avatar
well with any aftermarket speakers put in to improve sound you should get a better higher power amp. But its not necessary. Why do you have 4 tweeters? I guess the best we can tell you is Buy speakers and try them out. we dont know what sounds good to you.
Old Sep 29, 2006 | 07:48 AM
bluesdog64's Avatar
How hard is it to remove the door panels?
Got a Chilton's manual but it doesn't really delve into that subject.
Old Sep 29, 2006 | 08:56 AM
fsttyms1's Avatar
Very. Its a 2 min job at most.
Feb 25, 2020 09:57 AM
sockr1
Oct 1, 2015 01:31 AM
Pegon95
Sep 15, 2015 01:54 PM
Aleax
Sep 11, 2015 11:31 AM
alan_rich
Sep 7, 2015 11:08 PM
