CEL after midmuffler removed
Old Mar 19, 2010 | 06:09 PM
xtremex626's Avatar
Regional Coordinator (SoCal)
Just got my midmuffler removed and replaced with a pipe .. why am I getting a CEL ? Have any of you guys with the midmuffler removed experienced this too ? I hate driving with the CEL on .. bothers me :[
Old Mar 19, 2010 | 06:12 PM
assclown's Avatar
2000 acura tl FPR
yaaay you got your car back....
did you get a code read?
Old Mar 19, 2010 | 06:35 PM
xtremex626's Avatar
no i didn't .. but im sure it'll be something about my exhaust ): . i feel like taping my dashboard so i dont see that freakin light
Old Mar 19, 2010 | 06:44 PM
jjashaa's Avatar
Avant Garde Wheels
i had a code scanner... gave it back... get it checked and tell us what it is..
Old Mar 19, 2010 | 07:49 PM
assclown's Avatar
2000 acura tl FPR
there's nothing electronic in the midmuffler nor would i think an o2 sensor would be in there. reason i say get code read because something could have coincidentally popped up during the install? i'm just taking shot in dark.
Old Mar 19, 2010 | 08:17 PM
fsttyms1's Avatar
I would look at the )2 sensors, the exhaust shop may have let it hang by the wire or yanked on the pipe hard enough to damage it. Reset it and see if it comes back on.
Old Mar 19, 2010 | 08:23 PM
Sohcisme's Avatar
yeah i just got my exhaust done and the second i leave i got a cel. so when i got home i jacked her up and the pins were pulled out a little from the o2connector. i just pushed them back in reset the ecu and CEL never came back.
Old Mar 19, 2010 | 08:24 PM
xtremex626's Avatar
exactly what happened. i just went to get it read. PO141. they didn't use a stand when they removed the mid muffler .. man sigh .. they only used the stand right after it was left hanging .. lol
Old Mar 19, 2010 | 08:25 PM
xtremex626's Avatar
i told the guy to reset it and he did .. but right when he turned the car on again .. it went back on instantly ..
Old Mar 20, 2010 | 01:54 AM
jjashaa's Avatar
Avant Garde Wheels
tell them to replace your o2 sensor for free with OEM.. none of that cut off old one and splice/solder in new one... crap job... i hope you paid like.. $5....
Old Mar 20, 2010 | 11:52 PM
OverGloc's Avatar
It not the sensor. Tell them to check for Leak where they weld it. Same thing happen to me just a little needle size leak.
Old Mar 21, 2010 | 09:47 AM
fsttyms1's Avatar
A leak in the exhaust where the resonator or mid muffler are would NOT cause it. I have run NO exhaust from the cat back and it never triggered it, nor should it. They damaged his O2 sensor.
Old Mar 21, 2010 | 10:14 AM
assclown's Avatar
2000 acura tl FPR
like kris said, if it was a leak it wouldn't trigger a CEL, it would just be annoyingly loud.
Old Mar 21, 2010 | 10:42 AM
Sohcisme's Avatar
Its the pins pulled out a little on the connector of the o2 sensor for sure.
Old Mar 21, 2010 | 11:36 AM
xtremex626's Avatar
I went yesterday to get it checked.. all 4 pins were disconnected when he checked it.. the guy doesn't know which color pin goes into which hole ... any of you guys know which pin goes in which hole ?
Old Mar 23, 2010 | 11:41 AM
xtremex626's Avatar
went to the muffler shop yesterday and had them fix my o2 sensor up. like sohcisme said, just push the pins back into the connector. all 4 of mines got pulled out, so it took them awhile to figure out which pin goes into which hole .. but in the end, no more CEL !
Old Mar 23, 2010 | 12:38 PM
fsttyms1's Avatar
Just saw this. Glad they got it figured out. (if not i could have given the pin/color
Old Mar 25, 2010 | 09:34 PM
weirdxpsycho's Avatar
Im thinking of getting mines removed too. Is it loud and how does it sound? i dont trust youtube sounds =]
Old Mar 25, 2010 | 09:46 PM
oh and i was just wondering is it only for sound? and do you recommend it. i dont want anything loud cause cops in my city are very dalsfkjas about it
Old Mar 25, 2010 | 10:27 PM
xtremex626's Avatar
midmuffler is only for sound . tsudo sp's were too damn quiet .. so i had my midmuffler removed .. it sounds nice and deep now .. its not really that loud tbh . its bearable . i'll post a vid up soon .
but if you're stock and just plan on doing the midmuffler removal .. it won't sound THAT loud after .. theres videos on youtube you can watch but like you said .. you don't trust youtube sounds .. guess you gotta hear it in person
Old Mar 26, 2010 | 03:14 PM
is there any downside on doing this mod??
Old Mar 26, 2010 | 08:28 PM
assclown's Avatar
2000 acura tl FPR
yeah, if you don't like being awesome.
Old Mar 27, 2010 | 02:42 AM
xtremex626's Avatar
there is no downside .. midmuffler delete is like removing the resonator .. it's just for sound .. with the midmuffler on ... it basically resonates the loud engine noise . you don't lose power or mpg .
Old Mar 27, 2010 | 01:01 PM
notbrant's Avatar
http://www.youtube.com/watch?v=8mfDzjIOOpg
That is no mid muffler, AERO AR25 resonator, and Magnaflow "RACE" mufflers, which i believe are just large resonators, after 12 seconds, that is basically what the car sounds like, check out my other video for mid muffler delete, aero resonator, and stock mufflers.
Old Mar 27, 2010 | 01:48 PM
dudeinaTL's Avatar
The downside is you might get a CEL if you aren't careful....
Old Mar 27, 2010 | 02:07 PM
xtremex626's Avatar
^ negative. you won't get a CEL at all unless the muffler shop (like mines) doesn't use a stand when cutting off the midmuffler. basically causes the pins to get pulled out when the rest of the exhaust falls/hangs. make sure you tell them to use a stand. it will save you time from putting back the pins (in my case, all 4 were pulled out when the exhaust fell/hanged). putting back the pins would also require to use a lift, unless you have a racing jack & good lighting underneath.
and if you do get a CEL for anything other than the pins getting pushed out.. it's most likely a leak in the weld. just tell them to reweld it and clear the code.. should be good to go after. but otherwise, this is just a cheap mod for sound
Old Mar 27, 2010 | 02:11 PM
dudeinaTL's Avatar
You just said what I said in different words...
Old Mar 27, 2010 | 02:43 PM
xtremex626's Avatar
i was just being more specific so people reading thru this thread would know what to do in that situation
Old Mar 28, 2010 | 02:21 PM
lol luckily i am awesome
and thx guys for all the info
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
dainmezron
Oct 16, 2015 06:56 PM
samson_420
Oct 8, 2015 01:47 AM
hrothgar02
Sep 28, 2015 11:08 AM
lowgrowl
Sep 26, 2015 05:18 PM
