CAI quickie
Old May 1, 2008 | 12:08 AM
earthbound741's Avatar
Acura Newbe
CAI quickie
ok,
so i got a 99. if i get the CAI kit for 2000-2003, it should fit fine after i do the baby radiator bypass right?
Old May 1, 2008 | 12:23 AM
'03TL-S's Avatar
CAI's for 99-03 is all the same unless it's for the type S because the type S's throttle body is bigger.
Old May 1, 2008 | 06:54 AM
Acura Newbe
ya but 99 have the little radiator...
Old May 1, 2008 | 07:31 AM
fsttyms1's Avatar
Yes they do but the intakes are ALL the same UNLESS you have a type-s. They have a shorter intake and a larger dia
Old May 1, 2008 | 09:15 AM
Acura Newbe
how do you guys recommend i do the bypass. i mean like how to connect the two hoses together?
Old May 1, 2008 | 10:31 AM
'03TL-S's Avatar
What do you mean bypass? like so your motor won't hydrolock?
Old May 1, 2008 | 11:26 AM
oVerBoost's Avatar
HELP!
if you're talking about the bypass valve, you're gonna have to cut the intake and mount the valve in between the two halves.
Old May 1, 2008 | 11:37 AM
fiznerch25's Avatar
99 TL p
i think he is talking about the coolant lines that run through the stock intake box. all that comes out and you splice the two line together. I have an injen cai in my 99 tlp and it is for the 2002-2003 model works fine. search you will find all the answers you need to know
Old May 1, 2008 | 02:01 PM
fsttyms1's Avatar
just splice them together with a brass barb connector or follow them to their source and loop one of the hoses to the other end
lanechanger
Oct 13, 2015 10:56 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
h22lude
Sep 27, 2015 06:22 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
DDTsx06
Sep 8, 2015 06:56 PM
