blacking out headlights.
Old Dec 5, 2009 | 09:36 PM
ac-inblack's Avatar
Does anybody provide this service that has a spare pair for 03 tl? I saw a couple people that do it, but it was for the 3g. its my dd so can't afford to have it down. Thanks
Old Dec 5, 2009 | 10:06 PM
jjashaa's Avatar
Avant Garde Wheels
bummer, i had a spare set of stocks in my garage.. just sold those to someone local..
spend a saturday and do it! its a great learning experience...
Old Dec 5, 2009 | 10:15 PM
ac-inblack's Avatar
Talking
I've been thinking about it. Just afraid to screw it up or burn my house down.
Old Dec 5, 2009 | 10:16 PM
jjashaa's Avatar
Avant Garde Wheels
haha, yea, that was me when i was so eager to do this mod.
i just manned up, pulled the lights of my car and got to work.
once i started opening one up, there was no turning back. haha.
Old Dec 5, 2009 | 10:27 PM
ac-inblack's Avatar
lol i hear ya. Probably what i'll end up doing. I've read a few of the how tos and it doesnt seem too bad. We'll see
Old Dec 5, 2009 | 10:31 PM
jjashaa's Avatar
Avant Garde Wheels
^ you could always search around on ebay($150-$250 for a set, i bought mine separately for $200 for both), get a spare set of headlights and use those to work on so you don't have any downtime on your car. This way you can take your time with the headlights to make each detail perfect.
then keep the stock headlights just in case the ones you worked on leaks.
Old Dec 5, 2009 | 10:40 PM
ac-inblack's Avatar
Yep its probably what i'll do. especially after seeing your car. (looks very clean). Mines a nbp with oem lip kit too and those headlights just make a difference in my opinion. Thanks for your insight.
Old Dec 13, 2009 | 01:12 AM
III.II's Avatar
would you guys say its easier to put the headlights in the oven or use a heat gun to open them??
Old Dec 13, 2009 | 01:20 AM
Kline's Avatar
heat gun
heat gun is the best way to do it. save up time and headaches. also its easier to open the lights
Old Dec 13, 2009 | 03:11 AM
III.II's Avatar
How do you guys clean the chrome off the plastic before painting?
Old Dec 13, 2009 | 03:53 AM
iforyou's Avatar
You'll Never Walk Alone
I sanded the chrome off...I started using 150grit, then 400..then 1000, then 1500...before I went to paint it.
Old Dec 14, 2009 | 03:08 AM
III.II's Avatar
Would this combo be fine? or would you guy prefer high temp paint?
Old Dec 14, 2009 | 08:54 AM
ac-inblack's Avatar
I've read that some people use duplicolor or rust oleum. The one you have above says metal, wood, wicker not sure if that is your best option. Plus duplicolor sells high build primer so it may hide imperfections better. Not a pro just letting you know what i have read on here.
Old Dec 14, 2009 | 01:12 PM
III.II's Avatar
anyone else try the paint that i have above?
Old Dec 16, 2009 | 01:42 AM
kp4lyfx's Avatar
personally i'm going with the duplicolor adhesion promoter/primer and the rust-oleum high heat gloss black engine enamel.
Old Dec 16, 2009 | 02:39 AM
jaMezBOI's Avatar
philly flickin'
Im paiting my headlights as we speak. Im using KRYLON FUSION for plastic. Hopefully it holds up.
Old Dec 16, 2009 | 03:08 AM
JterrorC's Avatar
Always a Honda =Þ
whats the roughest??...y u switchin...whats the idea behind it???
Old Dec 16, 2009 | 02:06 PM
MIYAKUZA's Avatar
III.II. - I used the EXACT same primer and paint. It came out great! Make sure you tape the chrome on the inside of the corners because that is where your bulb will reflect light. I kinda forgot to do that for mine but its not a big issue.
Old Dec 16, 2009 | 02:09 PM
III.II's Avatar
Wouldnt the chrome peel off along with the tape?
Old Dec 16, 2009 | 02:34 PM
jjashaa's Avatar
Avant Garde Wheels
^ painters tape.
never any problem here. =]
just gotta be careful when you take off the tape
Old Dec 16, 2009 | 03:20 PM
iforyou's Avatar
I used Krylon Fusion flat black paint. I just like that more so than the gloss black.
jterrorc, the smaller the grit number, the rougher it is (150 is rougher than 400, and 400 is rougher than 600, etc). It's faster to use rougher sand papers first to sand off the chrome first, then you make the surface smoother by using finer sand papers (1000, 1500 grit).
Old Dec 16, 2009 | 08:53 PM
jaMezBOI's Avatar
philly flickin'
I used painters tape to tape off some parts and the chrome peeled off. Just be really careful when taping off the reflective parts and try to gently put the tape on. Luckily I tested it before I put it on the reflective part.
Old Dec 21, 2009 | 04:42 PM
JterrorC's Avatar
Always a Honda =Þ
i sanded the chrome off...i started using 150grit, then 400..then 1000, then 1500...before i went to paint it.
Old Dec 21, 2009 | 05:39 PM
iforyou's Avatar
Originally Posted by JterrorC
lol..you missed my other post on dec 16th...here it is:
Old Dec 22, 2009 | 12:35 AM
JterrorC's Avatar
Always a Honda =Þ
no i was askin what is the idea behind switchin sand paper roughness....
Old Dec 22, 2009 | 09:25 AM
ac-inblack's Avatar
^rougher sand paper gets the chrome off quicker and easier(or any painted surface) then the finer sandpaper smooths it.(finer scratches) so when you paint there won't be big gouges. With the rougher sand paper the primer or paint won't hide rougher scratches.
Old Dec 28, 2009 | 03:32 PM
JterrorC's Avatar
Always a Honda =Þ
^^ gotcha...
Old Dec 28, 2009 | 05:24 PM
gold2003tl (90)'s Avatar
2003 TL-p
after i blacked mine out i sealed them up real well, and they don't leak in the rain at all. but every time i drive when its below freezing outside they fog up and condensate. i aired them out one day with really dry air and still no luck. does anyone have this problem? im guessing humid air is trapped in them?
Old Dec 28, 2009 | 05:35 PM
iforyou's Avatar
when I had a bad seal before, they didn't leak in the rain. They only leaked when I went to wash my car. So I'm guessing you might want to reseal them, and apply A LOT of silicone. Also, try putting some silica gels inside the headlight housings. They help absorb moisture and have worked very well for me.
Old Dec 28, 2009 | 05:50 PM
2003 TL-p
i put tons of silicon, and i sprayed my headlights with a hose to check for leaks and none, ill give the silica gels a try to see if it will take some of the humidity out the air that must be trapped in there.
Old Dec 28, 2009 | 09:52 PM
ANC297's Avatar
Bonki' Ehrite!
I may be doing mine tomorrow, so I will keep you guys posted!
calrow
May 3, 2017 10:21 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
JDM96specCTR
Oct 17, 2015 01:06 PM
kev87a
Sep 26, 2015 02:30 PM
blackwarrior
Sep 26, 2015 09:09 AM
