Blacking headlights
13.2@ 107 on Street tires
Blacking headlights
Can someone please give me detailed instructions on how to paint the inside of the headlight housing? I wanted to just buy some but havent had any luck. Also as an alternative, are there any good headlight tints?
If you just want to buy some pre-blacked here you go. Its the best deal I've found on Ebay for them. More expensive, but less work involved haha
Mod Edit... No Ebay links
Have anyone ever bought those lights before? i wanted to know the condition of it as i need to replace my old ones due to scratches and rock chips. i figured a pair bran new would roughly be about the same cost.
Originally Posted by 4u2nv
Does anyone know if those are oems or aftermarkets? and any difference? thanks for help
Originally Posted by type-s09
those lights are the same design as 00-01..it would downgrade the looks due to the glass protector over the hid bulb...thats not for 02-03
hey, wat do u mean by downgrade the looks due to the glass protector over the hid bulb?
Why not just take yours apart and paint them. All you have to do is open it up, sand the chropme area down with some fine grit paper (like 320-400) and paint them black. Its not rocket science and there isnt any special thing or paint you need to do it
Oh my bad, didnt even notice you had the later 2nd gen. But on "downgrading the look"...no it wouldnt. It only would if you had no sense and installed them on the 02 or 03 model, which the housing is a completely different outer design anyhow. So yeah IF you installed them on a 02 or 03 like a moron it def would downgrade lol
. That and you'd have an odd dip in your bumper where these HL's dont fill
. And as for quality, a buddy of mine has these exact ones and they are made exactly like the oem ones, just black. Its quality stuff IMO, but to each is own.
You dont HAVE to sand the chrome, but considering those D2R bulbs get pretty hot, you would want to. The paint will just adhere better to something a little bit courser. Also, you wouldnt need to sand the chrome off, or even destroy its look. you just throw some 300-400 grit sandpaper on it, which feels a lot rougher than it really would be on the chrome, and use it until you see little swirl marks on the chrome. If you decide to back out, or ever want to un-black them, you sand the black paint and primer (which you should use for maximum durability) off, then use 1500 grit, followed by 2000 grit, then 2000 grit w/ 3M "1500-2000" rubbing compound together, then just the compound to bring it BACK to the original shiney chrome.
"Blah Blah Adam, shutup and just answer the question" yeah i know, but i just thought i might address a few future questions that could arise
Goodluck
Goodluck
lol, good description. But unfortunatley today my black housing project failed. I wasnt able to take the back cover off the actual HID Bulb on one of the headlights (the plastic piece which your supposed to twist to unlock).. meh, maybe i'll give it another shot some day.
Turn harder
also theres something involving a #20hexagonal bit you need for something, but thats for the 02/03 models. Not sure if we need it or not. I'm doing mine tomorrow
Originally Posted by PiZauL
Do you really have to sand down the chrome? All the DIY's I read no one has sanded down the chrome, they just spray over it. I plan on blackhousing this weekend.
Originally Posted by adamlee05
Turn harder
this is what i did. I took the headlights off the car, to take them apart I stuck them in the oven to heat up the glue, then pulled them apart. The chrome piece that got painted will slide right out. I took it to a body shop and they painted it with car paint-base coat clear coat.
Originally Posted by xsharkbaitx19
Do you think that the blacked out headlights that ebay has will look good on a silver car?
Originally Posted by vzuptnguyen
do you need high heat paint or just normal paint?
handsom-hustla
Nov 13, 2015 05:04 PM
