Best Stainless Steel Headers
I have an 03 TL-P completely stock. I wanna start doing performance modifications so I've been doing some research. I've never modified any of my cars in the past so I'm very new to this. I was looking into stainless steel headers and just wanted some advice on the best brands. Thank you in advance for all your help.
I was considering stainless steel cause to my understanding ceramic headers can sometimes crack. While researching I came across OBX racing headers but don't know if that brand is any good. Also, how much does Comptech go for???
Goodluck even finding it. It's an extremely rare performance part for our cars. Only worth getting if you live in California due to CARB laws.
With the money you are willing to spend, custom long tube headers are the way to go. Way better performance, but more work.
People cant see them driving down the road. Ceramic coated helps keep the heat in the header which in turn creates more power
Cracking really comes down to the metal used for the actual header and welds (and fitment, if forced together they will crack). A good set will last. I had a few sets of DC ceramic coated headers over the years on other cars and never had a crack in any of them with all of them having well over 200k miles.
We carry the DC Sports Ceramic coated stainless steel headers for your vehicle for $380.89! You can order them right from our website by adding them to cart and proceeding with checkout.
DC Sports Ceramic Headers - Excelerate Performance - Japanese and European Performance Specialists!!
Headers shouldnt be bought for eye-candy
Cracking really comes down to the metal used for the actual header and welds (and fitment, if forced together they will crack). A good set will last. I had a few sets of DC ceramic coated headers over the years on other cars and never had a crack in any of them with all of them having well over 200k miles.Unless we are Wooting all day the headers wont get extremely hot so having that Ceramic Coat is rather pointless to the guy who just wants more power but still open the hood for show in shows?.. I've seen plenty Hondas with SS Headers and they don't melt of damage anything from the header radiation I don't think we would either.
My DC Sports did crack on me with less than 100K on them bad batch I presume? Still wont send them back just for that, Installing them was PITA as is..
I'm running the current XS-power sport headers (Comptech clone) Worth every penny! Plus you can have them ceramic coated for what the DC's will cost and you'll have thinker better coating and they will clear the 6 speed engine mount if you end up going that route.
The only issue I've had with my DC Sports headers was leaking with the original two-holed flanges in their first batch for my TL-S. Once that has fixed, I haven't had any problems with leaking, or cracking for that matter. I've had the same pair for over eight years.
So you mean that outside temperature doesn't promote to make them rise even more in temperature? If outside is 200°F they will still get only to 600°F?
I thought:
Outside Temp High = Higher Temps
Outside Temp Normal = Normal Temps
Outside Temp Low = Lower Temps¨
At least the engine works that way.
I thought:
my OBX install
just installed my OBX headers after ordering direct from OBX on Amazon.com $280 shipped
just make sure that you follow the Header installs instructions to a T, the ones posted here on acurazine.com
also on my OBX the O2 sensor was supper tight against the tranny. unscrewing it causing the wires to twist and fail. Making for a parts run at 8:30 at night in dirty clothes for a new o2 sensor
Also on my Headers the holes were just a touch off - requiring me to grind on the mounting holes on the flanges. The middle upper bolt was a touch high - you can kinda see it in the picture.
I bought a set of Manzo M2-TP-048 headers on ebay. I was a bit disappointed by the way the header outlet flange suddenly steps down from 2-1/4" to 2" to match the stock catalytic converter. I replaced my '99 stock catalytic converter with a Magnaflow 2-1/2" inlet/outlet model that matches my 2.5" exhaust system.
I cut the 2" outlet flange off the header and welded on a short length of 2-1/2" tubing with a 2-1/2" 3-hole exhaust flange to fit over the 2-1/4" header outlet. The exhaust system is now 2-1/2" from the header outlet back, eliminating the stock catalytic converter flow restrictions.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
